Old 01-11-2020, 07:30 PM   #1
rusty_67
rusty_67's Avatar
Taillight Turn Signal Issue
Hey Folks,
So I've searched through the forum as best I can and can't seem to find any solutions to my problem, so...well...here it is:
All turn signal lights work fine. Park lamps come on as they should, as do the brake lights when brakes are applied.
Hazards work fine. Turn them on and park lamps and brake lights all flash as they should.
Now for the problem. When I turn on either turn signal (left or right) the park lamp and dash indicator come on, but do not flash, and the rear (brake) light does not come on at all. When brakes are applied, only the brake light opposite the direction of the turn signal comes one.
So far, to no avail, I've swapped the flashers and replaced the turn signal switch.
A little background, this is a fresh build, and I've used an American Autowire Classic Update Kit. The taillights are LED.
Any input would be appreciated, this one's got me stumped.
Cheers
rusty_67 is offline   Reply With Quote
Old 01-11-2020, 07:47 PM   #2
Mts67C10K20
Mts67C10K20's Avatar
Re: Taillight Turn Signal Issue
I've heard that LED lights need a special flasher for the low amp draw
Something to look into
Mts67C10K20 is offline   Reply With Quote
Old 01-11-2020, 08:04 PM   #3
dmjlambert
dmjlambert's Avatar
Also, some flasher modules are polarity sensitive. You can try using alligator clip test wires to hook up the flasher module with the pins reversed and see what you get.
dmjlambert is offline   Reply With Quote
Old 01-11-2020, 08:09 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Taillight Turn Signal Issue
Two very important things about LED's.
#1 is they want work if any of the wires in the system have been reversed. They are polarity sensitive.
#2 using the LED bulbs can cause all kinds of problems.
If all you have is LED rear lights and the fronts are incandescent you shouldn't need the flashers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2020, 08:12 PM   #5
rusty_67
rusty_67's Avatar
Turns out it was the flasher! Or at least so it seems. I happened to have one more on the shelf, swapped it in and presto, everything works as it should. I'm still confused as to why the tail lamp doesn't come on in that scenario though. One would think it would come on and just not flash. Oh well...
Thanks!
Old 01-11-2020, 08:15 PM   #6
dmjlambert
dmjlambert's Avatar
The "bad" flasher is either polarity or current sensitive.
Old 01-24-2020, 08:58 PM   #7
rusty_67
rusty_67's Avatar
So that flasher only kind of worked. It was blinking short-on long-off, then short-on longer-off, then short-on even longer-off, until eventually it just wouldn't come on anymore.
I tried reversing the polarity and didn't seem to change anything.
I've ordered the united pacific 90650 flasher, as suggested in another thread. I will see if that works.
Old 01-25-2020, 01:25 PM   #8
REDROCKER652002
My son's truck had something that sounds like you are having. I had the wires in the socket reversed. I pulled them, switched them and all seemed to work. And I used AAW as well. Great setup if you ask me.
Good luck.
REDROCKER652002 is offline   Reply With Quote
Old 02-06-2020, 06:34 PM   #9
rusty_67
rusty_67's Avatar
So just an update.
I got the United Pacific 90650 flasher in and it works perfectly! Makes me very happy.
Thread Tools
Display Modes
