01-14-2020, 11:24 AM | #1 |
Gas pouring from the tank fill !!
Okay... I know I could relocate my tank ....but I won`t ... Has anyone found a way to stop the tank from pouring out gas when making a right turn or going on a exit !!
01-14-2020, 12:01 PM | #2 |
Re: Gas pouring from the tank fill !!
Mine have never done that. Is the seal on your gas cap bad?
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
01-14-2020, 01:16 PM | #3 |
I forget what year they changed it. I know my 70 has a vented cap. I'm not sure if it was 71 or 72 they made the change to a sealed cap and a vent inside the truck on the passenger's C pillar (or is it a B pillar). With a vented cap, I don't know there is a good way to stop it. I've tried 3 different caps, same result. It only happens when my tank is full. If I keep it at ~3/4 of a tank, it has been fine.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
01-14-2020, 01:48 PM | #4 |
If you have a spill problem you might try one of these fuel flaps..
https://www.pciinc.com/shop-pci/150-...FLAP-p61376480
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
01-14-2020, 02:46 PM | #5 |
Couple of things happen.
1. They probably overfilled you at the station. I have had them do that on purpose. Tank most likely holds 2 or more gallons after first click on the fuel pump shut off. 2. Think I had a vented cap in the past, got the correct one and changed the gasket to a thicker one from ACE hardware, and no more issues. |
01-14-2020, 02:54 PM | #6 |
I haven't had this problem, but I recently switched to a vented cap because I read on this forum to do that to help with fuel/oil issues. My fuel pump died and fuel got into the block. Everyone on the forum said to switch to a vented fuel cap and put a new fuel pump on and it should work. Now I'm second guessing my decision to go to a vented cap...
1968 GMC C2500 Long Bed Fleetside |
01-14-2020, 03:12 PM | #7 |
My 67 did this on the ride home when i purchased it. Replaced fuel cap with new and problem solved, it had the original cap with a dried up gasket
01-14-2020, 09:30 PM | #8 |
I used to have the problem until I bought a quality cap.
Stant is the one I use, but as precaution, I don’t put more that 18 gallons in the tank, unless I’m making a road trip on the Interstate |
01-14-2020, 10:49 PM | #9 | |
Who Changed This?
01-15-2020, 11:42 AM | #10 | |
01-15-2020, 11:22 PM | #11 |
What vented cap is best, that looks original?
01-16-2020, 01:06 AM | #12 |
Who Changed This?
Mine is chrome plated. That looks good. I don't think that any other finish was offered for a cap that was outside. If you had a locking flap cover like the saddle tanks on my truck have, the cap could be galvanized with two ear flaps. That's what I have on the saddle tanks. You could use that for your main tank, but they are pretty ugly.
01-16-2020, 01:18 AM | #13 |
I bought a stant because I’ve always had good luck with them. I’m sure other members have their opinions. $10 shipped on rock auto
01-16-2020, 12:25 PM | #14 |
I got a chrome plated one from Napa, Stant, I presume. The gasket it comes with only lasts about 6 months, take it off and go over to ACE hardware. There you should be able to find a thicker more durable gasket that fits like a glove. Makes the gas cap tight, but not too difficult.
Let me know if you need some help with that, I could go over to the local store and get a whole bunch of them and spread them around! |
01-16-2020, 12:34 PM | #15 | |
01-16-2020, 02:16 PM | #16 |
Mine did that and a new gas cap fixed it. I also learned that the rubber grommet thru the cab isn't great so it would run back in the cab creating a nice "essence de unleaded" in the cab.
01-16-2020, 06:25 PM | #17 |
a vented cap isnt just a cap with a hole in it...it is sealed but has a one way valve to allow air into the tank to replace the fuel that is used up...your problem isnt that the cap is vented, your problem is that you bought a cap that is a piece of crap
1970 short step c10 leaf spring 454 |
01-16-2020, 07:38 PM | #18 |
I also have a Stant cap. Top my tank off every 10 days as my truck is a daily driver. 1968 C10 with the gas tank in the cab.
01-18-2020, 10:27 PM | #19 |
Old member
I cut rubber gasket material for a added gasket thickness works every time. I have done it several times.
Thread Tools | |
Display Modes | |
