12-07-2003, 07:14 AM | #1 |
Trans & X-fer case and more for sale
FOR SALE Make Offers
I know what this stuff is worth SM 465 w/ NP 205 Both originally out of 77' 3/4 ton I also have the pedal assembly and Z-bar a couple of extra driveshaft's with new U-joints 1350's one - is from and 87 K-20 LWB one peice with a slip yoke from a NP208 I think it is 27 spline but not sure i can check the other - is a custom made two peice (cost me $200to get cut down and balanced)with carrier bearing made to fit this trans and X-case set up in my blazer not sure on length at the moment but I can check but due to the angles involved angle shims will most likely be needed mine needed 8* but I never got them I changed my mind on the swap Also I have a steering column w/ keys shifter delete from same donor truck I'm not looking to get rich just get rid of this stuff I really don't want to ship anything I am only selling because my project became my daily driver and I don't need such a bulletproof set-up plus my wife can't drive a stick PM me with Questions Thanks,Keith
85 K5 BLAZER 305 TH400/208 3.08 REARS NO LIFT 95 DODGE RAM 2500 MAGNUM 360 4X2 EXTEND CAB-LONG BED If you can read this, thank a teacher. If you can read this in English, thank a veteran. |
12-08-2003, 08:30 AM | #2 |
i will get back to you with the details the parts are up at my shop i am probably going there tonight
Thread Tools | |
Display Modes | |
