01-22-2020, 12:42 AM | #1 |
Driving/fog lamps idea
I was thinking, if I put a 71-72 front bumper on my 70 are there driving lights that would mount in the openings instead of parking/ turn signal lights?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
01-22-2020, 12:57 AM | #2 | |
Re: Driving/fog lamps idea
Before I retired I drove about 35 miles one way a lot in the early morning hours during all sorts of weather, rain, sleet, snow, ice, fog and even nice clear weather also, LOL. I had a 72 1/2 ton at the time and mounted the FOG lights to the top of the bumper. Ran them on a toggle switch, worked out well. The amber fog lights WILL make a difference in vision but need to be mounted lower than the actual head lights. Most states actually have a rule for the height of mounted fog lights or driving lights.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
01-22-2020, 01:02 AM | #3 | |
Old member
I tried this many years ago and never found anything that looked right, I ended up doing 4" holes in it. You may have better choices now though. Here is a thread you may want to read. http://67-72chevytrucks.com/vboard/s...d.php?t=372441
01-22-2020, 02:05 AM | #4 |
I'm kind of interested in this myself as it'd look better than aftermarket pods hanging below the bumper
01-22-2020, 07:03 AM | #5 |
As Andy says, there’s a lot more choices now than there used to be. I’ve got two sets of LED lights that are small and rectangular, that would probably work. I went the same route as Andy though, as I measured and cut two 4inch holes in my 70 bumper. The lights really help on the back roads around my house.
I got the idea (before a saw Andy’s truck) from the bumper that LMC carries, but I didn’t want Chrome, so I did it myself |
01-22-2020, 07:10 AM | #6 |
Here’s a pic of my truck after I put the lights in
01-22-2020, 08:01 AM | #7 |
They make a custom bumper with driving lights
https://www.lmctruck.com/1967-72-che...bumper-lighted
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-22-2020, 10:30 AM | #8 |
01-22-2020, 11:04 AM | #9 |
Thanks guys. I do like the look of the round lights in the bumper. I think i'll put this on my future list of upgrades
01-22-2020, 11:24 AM | #10 |
20' Daredevil (Ret)
Fog lamps don't need to be amber, though many of them do have amber lenses. Clear fogs are also common. Whether it's a fog lamp or a driving lamp is determined mainly by the beam pattern, which is determined mainly by the design of the reflector and the lens. In a nutshell, fog lamps have a beam that is very wide, has a sharp horizontal cutoff, and does not reach far ahead of the vehicle. Driving lamps have a narrower beam that reaches farther ahead to augment your headlamps' high beams.
01-22-2020, 11:41 AM | #11 |
Old member
I'm going to do the front bumper on the 68 like the one on my 71 when I get time. It maybe a little different but basicly the same thing.
A few shots of the front end.
01-22-2020, 02:26 PM | #12 |
These are factory fog lamps from a 1957 Cadillac I added to mine. Glass front lens Looks period correct and the bulb has a cover on it to make it act as a true fog lamp. They are adjustable like the headlights as well. I am adding led bulbs to mine as I did all the other builds in my truck.
01-22-2020, 05:41 PM | #13 | |
Old member
01-22-2020, 09:58 PM | #14 |
Thanks. The lights are not too bad if you can find them. It's the bumper from the car that's brutal expensive. I needed it to cut the ring out of to mount it into my bumper otherwise the lights don't seat to the back of the bumper nicely.
01-23-2020, 12:16 AM | #15 |
I tried to put a '72 bumper on my '68 C/10 Stepside with the idea of fog lamps in the cut-outs. Didn't work because the mounting brackets are different. A friend with a chrome shop helped me out by trading the '72 bumper for a '67/'68 bumper and having one of his guys cut out slots for fog lamps and chroming it. I ran the chrome bumper with amber fogs [from Sears] for a while, then went back to the stock white bumper on the Stepside after a fender-bender.
I later had a '67 K/10 Suburban. In 1994 I hit a deer head-on just south of Tombstone. It needed a new grille and front bumper. I re-used the chromed one with the cut-outs. Only drawback was that I needed a bigger generator to run them at night, with wipers, heater, headlights, CB, cop scanner, and jamming stereo etc. Or the battery was quickly dead. I had a machinist make some truncated cones so the foglamps could mount inside the reverse slope of the inside bumper. They were bright in their day. Quartz-halogen.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-28-2020 at 03:26 AM. |
01-26-2020, 11:41 PM | #16 |
This took a keen eye and a decent amount of work to pull off. I'm a fan.
Cleverly disguised as a responsible adult... |
Thread Tools | |
Display Modes | |
