02-18-2020, 12:52 AM | #1 |
Battery Tray - Aftermarket Fitment Issue
howdy all, not a big thread starter but thought I'd share this little issue I ran into today..
replacing the battery tray in the red 71 longhorn while the inner fender is out from the heater core replacement.. this is the Classic Industries p/n CX1398 [part was tagged ESM-0651] for 67-72 w/o air, standard location.. I loosened the radiator mounting and tilted it back a little not to harm anything but leave enough room to access bolts.. if you're not the careful type, better to remove it so not to bend any fins over.. this four core looks original and pristine so I was careful.. removed the old tray easy enough, came apart in two pieces placed the new one in there, lined up the top holes and found the inboard lower screw wouldn't grab?? hmm, so crawled underneath to discover the rolled edge of the new tray occluded the mounting surface area so much that it couldn't lay flat.. I can't swear the one that came out was absolutely the original, but sure looked it.. also can't swear there isn't a spacer or something supposed to be in there, but nothing came out with the old one.. I didn't really have time to diddle with it, this was a 'while I'm already there' job anyways, so I cut it down with a 24 grit roloc fits like a glove, all three holes on inboard edge laid down flat, no stress risers in the bracket, both outboard holes lined up nicely.. I left the raw edge, if you could see what's below there you'd know why of course a clean job would be to finish the edge with soft paper, prime and paint.. hope this helps, cheers! rolled edge of aftermarket tray bracket not permitting mounting surface to reach.. that misalignment held the opposite side lower hole off as well.. aftermarket rolled edge not offset close enough to factory to fit without modification.. I cut enough to clear all the way around to eliminate riding or rubbing on core support.. we have clearance clarence looks like a slight indention where the original may have had a little too much offset as well
I started out with nothing - and I still have most of it |
02-18-2020, 08:55 AM | #2 |
Re: Battery Tray - Aftermarket Fitment Issue
Pics??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-18-2020, 11:25 AM | #3 |
Almost Satisfied
Mine was the same way...always something.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-18-2020, 11:36 AM | #4 |
I got one from ebay and did not have to "adjust " it in any way. Just bolted right in. Goes to show you that it down realy matter whare you get parts. They all sell the same Chinese junck. Just differnt prices.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
02-18-2020, 12:32 PM | #5 |
pics may take a second or three to load but should be there, still showing up here and phone..
the tray assembly is remarkably similar to the original design wise, just not executed the same fitment wise.. I see they sell the tray itself but the original and this one are spot welded together.. so welding required or modification with fasteners of some type to install that one?? this one had a taiwan sticker on it but something so common is probably made in every province of china my bad for not researching, didn't think something so simple would need fitting, not like it's an operating part like a door or something anyways, classic industries is on the way to my dentist and I needed some other stuff while I was there.. during the week short line and saved on shipping.. but saturday I stopped in to pick up some parts and whoah! lobby was packed! guy pulled into parking lot right as we did and ended up walking out after seeing crowd.. I talked to him for a second, he has a '65 like I do and turned out is also a forum member anyways, he had to go but we waited it out, 30 minutes to get to the counter even with phone order, and another hour to get parts pulled! I was literally attended to by someone for combined less than 5 minutes.. but lots of others were chatting at the counter so maybe free shipping deals for better parts may be in my future, that is if better parts can be found and verified
02-18-2020, 01:41 PM | #6 | |
Nice to have but man it can be a real pain. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-18-2020, 03:06 PM | #7 |
Old member
I just installed a aftermarket battery tray without issues at all. It fit as good as the old one did.
02-19-2020, 10:10 PM | #8 |
I have other battery trays to replace in the near future, could some of you with successful fitting parts recall part numbers or vendors you purchased from?
I did find a good aux tray from a member that gave me a good deal but figured most takeoff primary battery trays would be eaten up.. and a good forum deal doesn't always come along when you need something.. thanks in advance for any input!
02-20-2020, 11:14 AM | #9 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-20-2020, 01:30 PM | #10 |
Post Whore
I'm linking this thread to the aftermarket sheet metal thread.
https://67-72chevytrucks.com/vboard/...85#post8681585
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-20-2020, 02:07 PM | #11 |
Old member
Here are a couple of pictures of mine. It fit good as far as I can tell. The inner fender also fit good. I bought them together. I bought the AC one so when I add the AC later I'll have the clamp for the hoses.
Thread Tools | |
Display Modes | |
