Old 02-24-2020, 05:23 PM   #1
54blackhornet
54blackhornet's Avatar
Exhaust Down Pipes ?
I’ve decided to build my own dual exhaust because of the cost at my local shop. 350, LWB leaf-spring rear. Reviews talk about one down pipe not being correctly bent ? Can anyone confirm this or suggest a good set. I located this 2.5 Stainless 3 bolt flange. Appreciate any thoughts.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-24-2020, 07:01 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Exhaust Down Pipes ?
I just had the local shop make me a set for the 68 step. He did it in about 2 hrs and charged me $100.00 for both. He welded them into the exhaust for me also. I can drop the starter without taking the passenger side loose I think. 2.5" pipe.
One guy wanted $250.00-$300.00!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-24-2020, 11:44 PM   #3
Vero67
I used Heartthrob for the exhaust on my 67 K10. Due to the Rockwell transfercase the passenger side wouldn't work, which I knew. I mocked up what I needed with flexpipe, then had the local shop bend me a down pipe. $60
Vero67 is offline   Reply With Quote
Old 02-25-2020, 07:30 AM   #4
notsolo
notsolo's Avatar
LMC...Heartthrob kit for a LWB with leaf springs is $450 ...Emailed Hearthrob about the difference in the down pipe. Did not get a definitive answer, said the kit was only about a year old...I have seen it talked about here since 2015.? I bought a generic kit from Summit $150 delivered 2.25 pipes, no down pipes or mufflers. I don't think anybody makes the down pipes with adjusted angle on the rt side...Could be wrong...Maybe somebody will chime in with the answer.
notsolo is offline   Reply With Quote
Old 02-25-2020, 11:59 AM   #5
54blackhornet
Thanks guy ! How can this be after all these years ? I guess they just don’t care ? Crazy !
71 C-20
07 Magnum RT AWD
Old 02-25-2020, 05:42 PM   #6
Andy4639
Old member
Andy4639's Avatar
Here is some kits you may want to check out.
2.50" SS Stainless Steel SS409 Dual Exhaust Downpipe Kit System 67-72 Chevy/GMC C10/C15 1/2 Ton 2WD Pickup Truck. Fits Small Block V8 Angled Ram Horn...
https://www.amazon.com/Stainless-Exh.../dp/B07SG7CGGL
JEGS
https://www.jegs.com/i/Pypes+Perform...IaAgqJEALw_wcB
https://www.tunersports.com/magnaflo...80_p49182.html
Old 02-25-2020, 06:54 PM   #7
54blackhornet
I already came across the first one you listed, both pipes have same angel .
71 C-20
07 Magnum RT AWD
Old 02-25-2020, 10:03 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Exhaust Down Pipes ?
I'm not home are I would look at my 2 trucks and snap some pictures. I would think it wouldn't be that far off. If they say they fit 67/72 they surely had to install them at some point.
Old 02-26-2020, 04:37 PM   #9
54blackhornet
I contacted Pypes today . They off 2.5 SS Down pipes that where recently modified to fit our trucks . Going to pull the trigger on a set from Jegs. $165.00 shipped. Will report back on fitment.
71 C-20
07 Magnum RT AWD
Old 03-03-2020, 04:42 PM   #10
DA71Grande
DA71Grande's Avatar
I have some magnaflow down pipes that are for a c10 hopefully the will work for my c20 they do have some slight bends to them not sure how correct they are to fitting.
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 03-03-2020, 06:59 PM   #11
54blackhornet
Could you tell us where you got them and hw much ? 2 1/4 or 2 1/2 ?
71 C-20
07 Magnum RT AWD
Old 03-03-2020, 07:47 PM   #12
DA71Grande
DA71Grande's Avatar
I got them from here https://www.hottexhaust.com/Magnaflow_15380 they also offer a 20% discount and free shipping so it was around $180.
Doug
23 Chevy Tahoe Z71
Old 03-03-2020, 09:01 PM   #13
Andy4639
Old member
Andy4639's Avatar
I put 64 Impala down pipes on the ramp truck. I had new exhaust installed on the 64 right after I bought it. I took the old exhaust and used it on the ramp. Friday morning it gets the stacks hooked up to it.
Thread Tools
Display Modes
