02-27-2020, 10:26 PM | #1 |
Needing a parking brake cable
I have a 68 C10 with a rear end charge someone put a 12 bolt rear end in the truck before I got it and don't know what end cable to order for the parking brake the end that goes into the wheel can anyone help
02-27-2020, 11:16 PM | #2 |
Re: Needing a parking brake cable
From my experience with a 1971 C10, you at least need to ID LWB or SWB, coils Vs leaf springs, and connector type at the wheel plate.
In my case the reputable dealer still sent the wrong ones. That's what I get for a SWB, 2WD C10 W leaf springs "they'd never seen before". I had to send them the right ones.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-28-2020, 08:22 AM | #3 |
Old member
LMC has the cables and such.
#5 is the cable going into the back wheel. https://www.lmctruck.com/1967-72-che...g-brake-cables
02-28-2020, 09:31 AM | #4 |
Pictures of the backing plate for the brakes would help. As was stated before, coil or leaf spring and long or short wheelbase. I just replaced those exact cables on my 67 and got AC Delco cables from RockAuto. Not very expensive and fit like the originals.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
Thread Tools | |
Display Modes | |
