Old 02-28-2020, 01:50 PM   #1
MDPotter
MDPotter's Avatar
Anyone install DJM flip kit recently?
I'm looking at installing the DJM flip kit on my truck and was curious if anyone has done it in the past 2-3 years. My truck must have the HD rear spring option because I have a total of 8 leaves. If I go with the flip kit, I would take out the bottom 3 leaves and leave the rest. Also, what to do about the shocks? They'll be at a bad angle unless I relocate them and I'm not even sure the stock mounting locations will work with that much drop.
I have a 2-3" drop shackle on it now but it's conflicting with my bed floor and I'd like to get more drop.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 02-28-2020, 10:02 PM   #2
sKnNyPpY
sKnNyPpY's Avatar
Re: Anyone install DJM flip kit recently?
don't remove leafs, I went with HD 5 leaf packs over 3 and love it, my post on my experiences back in the day: http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 02-28-2020, 10:06 PM   #3
sKnNyPpY
sKnNyPpY's Avatar
relocating the shocks is included in the thread and I would go back with stock shackles and bushings over the drop ones unless the 8 leafs keep it up correctly. I have no notch and haul loads of mulch and sand no problemo
Old 02-29-2020, 09:50 AM   #4
Mike C
Mike C's Avatar
I have the HD springs on my ‘69, and they do not look like that. With that said, I removed the overload on mine because it was interfering with the Cal-Trac bars.
On yours, I would remove all the small leaves below the overload, not sure why they are installed? I would keep the overload unless like myself you are running some traction control device.
The flip on my truck lowered it 7 1/4” in the rear. I drilled the factory upper shock mount second hole out and move the shock to be more vertical. With a 4.5” drop in front (2.5” spindles, 2” springs) I used stock length shocks all the way around.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-02-2020, 10:45 AM   #5
MDPotter
MDPotter's Avatar
Thanks for the info guys. I was able to get the stock shackles put back on this weekend but didn't get to put on a bedside and do some measuring. I'm torn between the flip kit for a 4.5/7 drop and a drop spring for a 4/2 drop.
Old 03-02-2020, 10:58 AM   #6
notsolo
notsolo's Avatar
Where is your fuel fill ? ....if its in the bed side could be an issue.
notsolo is offline   Reply With Quote
Old 03-02-2020, 12:12 PM   #7
MDPotter
MDPotter's Avatar
It's through the bed floor.
I'm looking at 4" drop leaves. I think 7" will be too much.
Old 03-02-2020, 02:11 PM   #8
notsolo
notsolo's Avatar
Reason I asked about fuel fill, I bought DJM 2 " drop shackles, my fuel fill is in the side....LWB....wrong place for these parts.....
Old 03-02-2020, 04:25 PM   #9
MDPotter
MDPotter's Avatar
I just ordered 4" drop springs from Summit (Western Chassis) and u-bolts. With these, I will end up with 4" or more because the spring pack on my truck is more than most 1/2 tons I've seen on here. If my springs have no sag in them, I can see getting 5" or more just because the lower three springs on my truck are over 1" thick alone. I can't get a good picture of the drop springs, but I bet they're 3 or 4 leaves and I have a total of 8.
Thread Tools
Display Modes
