03-03-2020, 01:48 PM | #1 |
Old member
71/72 tilt wheel & horn video
I just finished installing a factory tilt wheel on the 68 stepper. I did a video of the wheel install and horn pieces so if your need info on it it's all here. I do raw video's no editing.
A few points to make. The turn signal cam has to ride on the copper spring loaded piece for the horn to work so if the wheel isn't all the way down it want work. There are 2 different horn retainers for these trucks depending on which wheel you use for the truck. You can see the differences in the pictures. https://www.youtube.com/watch?v=fI515M7mgVo
03-04-2020, 03:27 PM | #2 |
Re: 71/72 tilt wheel & horn video
Great video, This is something I will be working on soon. Thanks for sharing.
Thread Tools | |
Display Modes | |
