03-06-2020, 09:01 AM | #1 |
Active Member
temp gauge problem
i switched my 3 hole idiot lights to a factory 7 hole with gauges, i followed the diagram that i found here on these boards. since i have a 5.3 from a silverado and i want to add a volt meter i just eliminated the wires for the battery gauge. my problem is the temp gauge pegs to cold when turn on the key. i used the auto meter 2277 adapter and the 2259 temp sender. any ideas?
thanks Bryan |
03-06-2020, 10:48 AM | #2 | |
Cluster King
Re: temp gauge problem
Put a ground wire from The bottom post of the temp gauge to a known good ground and see what happens. Let me know. I can help you diag. Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
03-06-2020, 12:27 PM | #3 |
Active Member
ok ill do that as soon as i get home ...thank you
03-06-2020, 04:44 PM | #4 |
Active Member
ok i removed the wire. same thing key off the needle goes close to the c line key on it pegs to the bottom of the gauge (cold side). i put a jumper to the bottom lug on the gauge and got no difference.
03-06-2020, 04:56 PM | #5 |
Sounds like a ground issue. I had the same problem with my son's gas gauge. Found out that the whole dash is a ground. Once I screwed in the dash or ran a ground from the dash itself it worked. Not sure if that is your problem or not, but it was mine. Good luck
03-06-2020, 06:08 PM | #6 |
Active Member
ok here is what i found key off the needle is at the c line key on pegged to the cold sde is i ground the green wire it pegs to the hot side
03-09-2020, 08:27 AM | #7 |
Active Member
any ideas maybe a bad gauge?
03-09-2020, 11:38 AM | #8 |
Cluster King
Did you ground the gauge like i mentioned above? I have replacement temp gauge if needed.
03-09-2020, 01:00 PM | #9 | |
Active Member
thanks Bryan |
03-09-2020, 03:36 PM | #10 | |
Cluster King
I sell volt gauge conversion kits for $125.00 plus $18.00 to ship Total shipped with new temp gauge is $193.00 total, Or with used temp gauge , $168.00 total This will make your job simple. I will send you volt gauge conversion with temp gauge in place. All you do is install in cluster. PayPal is: support@classicgaugeandcluster.com I will need your address to ship. Thank you, Tom
03-09-2020, 03:45 PM | #11 | |
Active Member
Thread Tools | |
Display Modes | |
