03-12-2020, 06:47 PM | #1 |
WTB door hinge shims
OK gentlemen, I need some special assistance with this. My 67 GMC has newly rebuilt door hinges, but the driver door has a mysterious problem. When you tighten the driver door hinge bolts, the door creeps closer to the front of the truck toward the left front fender no matter how hard you try to stop it from doing so. It stays right up on the fender edge causing it to be impossible to open the door. So I need door hinge shims to create the necessary distance between my driver door and the left front fender. Does anyone on here make or have any? I failed to locate any on the internet.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
03-12-2020, 07:42 PM | #2 |
Re: WTB door hinge shims
Can you loosen the hinge-to-post bolts and slide the hinge back?
03-12-2020, 07:56 PM | #3 |
Tried that. It creeps forward every time.
03-12-2020, 08:34 PM | #4 |
So you need a shim or ( assortment of) shims between the door hinge and the A-pillar for Upper and lower hinge?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-12-2020, 09:36 PM | #5 |
Yes
03-13-2020, 12:40 AM | #6 |
Shims could be made for any of the 4 mounting pads of the door hinges.
Looking at the hinges I have / If I made a shim I would want a Full contact shim. Not a shim that would slip in without removing the bolts. You would just create more problems later.(Cracks , rust and pressure points etc.). The 4 mounting surfaces with shims added below: 1-Top hinge a-pillar post (which would bring the top of the door out-board) 2-Top hinge Door flange (Door away from fender) 3-Bottom hinge a-pillar post (which would bring the bottom of the door out-board) 4-Bottom hinge Door flange ( which would bring the door away from the fender) If shims are installed on the bottom hinge / This could be done easier than on the top hinge. The top hinge has the catch link to keep it open. With a full contact shim This would require removing the hinge/door each time until you got the correct result you are looking for. High Quality shim stock is (Pricey). If you think you have went the distance on all the adjustment of the slots in the hinges. This is your next best option. So with the info above. What do you think the thickness of your shim needs to be? If your shim needs to be about a 1/4 inch (0.125) That would take Qty. 4 shims per location of change of (0.030) which would be (0.120) If less gap smaller shims of coarse. Which shims do you need # number 1-4? What thickness? And How many? .
03-13-2020, 04:45 PM | #7 | |
I need these two. The door is way too close to the fender. PITA!!!
2-Top hinge Door flange (Door away from fender) 4-Bottom hinge Door flange ( which would bring the door away from the fender) Quote:
03-13-2020, 06:02 PM | #8 |
Do you know how thick of a shim you want?
I will take some pictures and post in a few. For idea's So you can determine thickness of shim you would want. .
03-13-2020, 07:13 PM | #9 |
Here is a picture of the measurement of the door gap, and one of where the fender meets that door. It appears maybe a shim between 1/8 and 1/4 inch will close the gap I guess...
03-13-2020, 08:57 PM | #10 |
I never ever, ever, ever, ever fit a door with the fender installed.
Did i say you should never try fitting a door with the fender installed? What does the rear gap look like at the cab to door? Body fitting procedure. Door to rear of cab, while minding the rocker panel gap. ignore the window frame. If necessary, Beat the window frame around to fit the upper cab opening Fit fender to door. If the gap is tight at the top then the cab mounts have sagged, shim or correct the cab mounts. The fender resting at the front should align fairly well top to bottom, with the door without force. Its almost never necessary but you can shim under the hinge at the door or the cab. I only do this after elongating the hinge holes, which is almost never necessary. These are standard body shims in 2 thicknesses. I can send what you see for shipping cost which is about $8. |
03-13-2020, 09:01 PM | #11 |
And remove the door latch or the latch plate while fitting the door so temporary latch mis adjustment doesn't influence the door alignment procedure.
03-13-2020, 09:12 PM | #12 |
I installed the door with the new hinges without the fender on there. I had done this before with the old saggy hinges with the same result. If you tighten the hinge bolts the door inexplicably moves forward to where it makes it impossible to put the fender on so that the fender and door do not touch. Once I put on the door then try to put on the fender afterward they are too close.
There is clearly some issue here.
03-13-2020, 09:26 PM | #13 |
Ok I will get the pictures I have.
In order to send a post. .
03-13-2020, 09:48 PM | #14 | |
Here is a BEFORE picture of the old door and old fender as it was when I bought the truck. As you can see the door and fender scraped each other even back then.
03-13-2020, 10:07 PM | #15 |
03-13-2020, 10:11 PM | #16 |
03-13-2020, 10:13 PM | #17 |
03-13-2020, 10:20 PM | #18 |
03-13-2020, 10:33 PM | #19 |
You can use washers to determine the thickness of shim that you want.
A solid shim could be made. You also need to measure the gap in the B-pillar /(Back of the door). If you move it back /do you have the room to make the gap Equal . .
03-14-2020, 08:06 AM | #20 |
it's not a door shim problem it's a body mount problem , Adding door jam shims may band aid the issue but it's not the right way to fix it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-15-2020, 05:31 AM | #21 |
How is the front tip of the fender and hood alignment ? and the hood to cowl alignment ? does it show the fender needs to go forward to match the hood ?
Original truck pic shows it was hit on the corner, maybe the whole side is pushed back and core support has moved as well, and frame is bent. Measure from firewall to core support on both sides to see if it is moved back. |
Thread Tools | |
Display Modes | |
