Old 03-29-2020, 12:01 PM   #1
Northern 52
Welding AD cab seam
Just curious, has anyone welded the seam across the outside rear of the cab on an AD? Mine is a bit rusty in spots and next to impossible to sand or grind it out. I'm not doing a full body and paint on mine, the plan is just a satin black finish but I really don't want rust reappearing annually. I was thinking flux core at low heat might work. Any thoughts?
Northern 52 is offline   Reply With Quote
Old 03-29-2020, 01:26 PM   #2
LOW A D
Re: Welding AD cab seam
I have welded that seam on one of my trucks. It was a lot of work to weld and grind it smooth. If I were to do it again, I would give the seam a careful sandblast, epoxy prime the area, then fill it with a quality filler such as metal to metal. I think this would be way less work with good results. On my present build I just gave the seam a quick sandblast and left it. Just my opinion!
My build- 51 Chevrolet
LOW A D is offline   Reply With Quote
Old 03-29-2020, 04:05 PM   #3
Northern 52
I like that idea. A lot less work for sure.
Thread Tools
Display Modes
