![]() Join Date: Apr 2017
Beating a dead horse - Vortec coolant bypass
Can’t believe I haven’t been able to find a decent solution between this website and the google machine, but here we are again.
I’ve got my bypass in the correct location (pardon the poor routing, we were in a pinch) and will be trying out some pre bent hose, but I’m curious if I can run the hose directly to the radiator spot circled in the picture or if I should just drill 2 3/16 holes in the thermostat. I haven’t been able to find a good solution and the motor got way hot when I first fired it up, probably due to trapped air at the t stat and my temporary hose. What solutions seem to work for you all? |
One of the First
![]() Join Date: Jan 2000
Re: Beating a dead horse - Vortec coolant bypass
Good question, I was searching the other day for some fittings or pre-made hose.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
![]() Join Date: Jan 2001
I went to the auto parts store and found a piece of pre-bent coolant hose, but I've got my coolant coming out where you have your temp sensor.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
That short bypass is hard to hook up.
Might be easier to use a spacer like this with a more accessible port and a longer hose. https://www.jegs.com/i/Meziere/680/WN0028B/10002/-1 |
![]() Join Date: May 2010
This is what I did on my Chevrolet Performance Vortec crate engine. Note the spacer under the thermostat housing for clearance. Seems to work fine.
Jim |
One of the First
Nice - can you divulge your sources?
![]() Join Date: Jul 2016
There is no good reason to not just drill the thermostat on every single new engine install or anytime the block is low on coolant from changing parts.
The hole will ensure the block fills completely with coolant. There is absolutely no down side to drilling the thermostat. I Usually fill the cooling system with the heater core hose off the manifold fitting until i see coolant flow out of it. I still do this with a drilled thermostat but its not really necesarry. |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
I believe the fittings were from an eBay source and not sure on the hose. I recall posting the info in another thread (possibly a PM) about 6 or 7 years ago. I spent about 2 hours looking for that thread but no luck. I'm pretty sure I have the receipts, but it'll be about a month before I can check. Big help, huh?
Jim Last edited by FirstOwner69; 04-16-2020 at 12:17 AM. |
![]() Join Date: Nov 2018
Been drilling thermostats since the 70's....never a problem. I even purchased a thermostat once that already had a vent hole in it from the mfg but have not seen one since.
![]() Join Date: Jul 2015
I have seen the rear of the intake manifold drilled and tapped with fitting coming from both heads. This would be from the rear and they route hoses up to somewhere???
If anyone has pics please post them up! |
At the body shop.
Kit with the similar spacer I posted above.
I dont know why you couldn't turn it around and use one of the fittings as a bypass. https://www.jegs.com/i/JEGS/555/51100/10002/-1
#13 |
When I transplanted a L31 vortec in my c10 , here is just some information I found , GM issued instructions state :The Ramjet 350 engine includes a standard rotation water pump this is a cast iron,LONG Leg water pump :the same pump installed on GM performance parts ZZ4 crate engine . Any small block engine regardless of year,that uses Vortec Heads,will require an external coolant bypass line from the intake manifold to the 5/8'' hose nipple on the water pump (passenger's side) suggested routing is from 3/8" boss on intake mainifold to water pump.
And here is some information I found and is vital in cooling a vortec engine: The serpentine belt that runs all accessories off one belt uses REVERSE Rotation water pump,because of the way the belt is wound around everything they use the back side of the serpentine belt wrapped in the opposite direction around the pump, Ford v8 serpentine belt is the same way,pump has to be a reverse rotation compared to earlier v- belt system pumps .. this is the information I used in my L31 transplant and my truck runs 181 -186 degree 99 percent of the time on very hot days 95 degree and up I will have up to 191 degree spikes on my engine coolant temp when stopped in traffic on very hot days. one more thing to remember: Engine driven cooling fans also have to match the pump,reverse rotation Pumps have to have reverse Pitch fans because they are spinning in the opposite direction, make sure the fan is also correct for your application or it will impact cooling also, using the wrong fan will try to push air foward through the radiator ,fighting road airflow and also leading to highway overheating . |
#14 |
That's an old circle track/sprint car trick. Some after market manifolds come pre-drilled and tapped for that purpose.
#15 | |
Looking at the dollars for a build. |
#16 |
At the body shop.
You could just buy the spacer. Plug one side and use the other side as the bypass?
#17 |
Or you could just drill the thermostat.
#18 |
![]() Join Date: Mar 2005
This is what I did. The bypass hose just touches the bottom of the rad hose.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#19 |
Post Whore
![]() Join Date: Feb 2016
I picked one of these 67 and earlier factory spacers for 5 bucks at the wrecking yard for my truck. One more piece of evidence proving the old lady right that I am a cheap ba$$terd.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#20 |
![]() Join Date: May 2012
Randy500: could you post a picture of a drilled thermostat housing? This is new to me-I like to learn all I can when I can.
edit: Never mind-I reread your post and saw that it said drill the thermostat, not housing. I know about that. But thanks anyhow. Doug Last edited by kidatheart; 04-16-2020 at 10:31 PM. |
#21 |
![]() Join Date: Sep 2009
I am slowly installing a chevy crate motor with vortec heads in my truck and hopefully soon will be to the point of routing cooling hoses,
I would appreciate seeing a picture of a drilled thermostat |
#22 |
There are a few t/stat manufactures out there that sell T/stats that already have bypass holes drilled in them , you can find these t/stats at places like Speedway and yes with pictures....
#23 |
Not my picture. I actually use a punch but a drill works fine. Some people drill more than one hole.
Many vehicles have a factory hole. |
#24 |
So after reading the posts about cooling bypass lines, you say its a simple as drilling a 3/16" hole just like the one in the picture? No cooling issues with that? Not doubting just asking. It makes sense, the bypass lines that the thermostat out of the equation.
#25 |
![]() Join Date: Mar 2012
this is funny there is another thread just like this on about 6 or 7 above,just drill a hole in the thermostat that i did also take a look at the other thread on this same subject i posted a link on there and as others
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Thread Tools | |
Display Modes | |
