Old 04-19-2020, 08:49 PM   #1
57larry
Anybody use Brother's seat brackets
I bought a set of Brothers bkts to lower my seat in my 68 cab with a 69-70 seat. The new bkts part # LSB6772 do indeed lower the seat but do not adjust the seat back enough. My gas tank is out of the cab and I have a 3 inch gap between the seat back and the back of the cab.
Now, I am not a tall man, 5'6" and my tilt column is down as far as it can go to the dash.
Anybody use this kit and are you taller and skinny? Thanks, Larry
57larry is offline   Reply With Quote
Old 04-19-2020, 09:14 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Anybody use Brother's seat brackets
Can you post some pictures?
dmjlambert is offline   Reply With Quote
Old 04-20-2020, 09:44 AM   #3
68Gold/white
Was your seat original to your pickup???
I think they make different brackets for different years...maybe...
There are 3 different stock type seat brackets for the 67-72 pickups...
There's a thread all about this...not sure if it will help, though. I will look, later
68Gold/white is offline   Reply With Quote
Old 04-20-2020, 04:55 PM   #4
57larry
Here are some pics as requested and also a pic of the original 69-70 seat bracket.
Old 04-20-2020, 08:46 PM   #5
firedemon
underneath the flap on the side of the seat where the top meets the bottom is an adjustment to make the top tilt back or forward . those brackets are supposed to be designed to give the full back position that the stock brackets do . an option looks like the brackets have enough to drill some holes further forward on the front
firedemon is offline   Reply With Quote
Old 04-20-2020, 09:02 PM   #6
57larry
has anybody on this board buy & use the lowering seat bkts sold by Brothers?
Old 04-20-2020, 09:23 PM   #7
OregonNed
OregonNed's Avatar
I haven't, but have you considered the custom lowering brackets offered by Full Custom Fabrication? Mine are perfect for me, and the seat is back to the full rear position -
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-20-2020, 09:55 PM   #8
57larry
good to know thank you but I already bought & painted the Brothers parts
Old 07-03-2021, 01:43 PM   #9
Brian_s
Ok did you ever find a solution to this I'm going through the same thing right now
Brian_s is offline   Reply With Quote
Old 04-11-2022, 01:30 AM   #10
howzzzit
howzzzit's Avatar
I bought the first set and the slots were cut too short. They sent a 2nd set with longer slots. Installed the seat and like the pictures there is a large gap at the top of the seat. I'm 6' 5" and they are useless as you're actually closer to the wheel and your legs are bent at such an angle it makes using the pedals more difficult. Very unhappy with these and Brothers in general. Going back to stock. By the way when you look at the photo of the seat on their website it is sitting directly on the floor with NO brackets. Sneaky.
howzzzit is offline   Reply With Quote
Old 04-11-2022, 01:08 PM   #11
MikeB
MikeB's Avatar
I saw those brackets, but my first thought was they would put my feet closer to the pedals, and make the non-tilt steering wheel too high.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-16-2022, 01:00 PM   #12
wayneharron
I looked at those brackets because once I put new foam and installed a new cover I was almost touching the roof. I ended making my own brackets and they let the seat sit 3 inches lower and slide all the way back.
wayneharron is offline   Reply With Quote
Thread Tools
Display Modes
