04-20-2020, 11:48 AM | #1 |
Pics? of 'Pump to carb' fuel hard line?
Anyone got a pic of a stock 'pump to carb' fuel hard line on their ride? Trying to find the right one for my 72 K10. My engine carb is a out of a 1975 truck, so I ordered one for that combo, and it was close, but not right.
04-20-2020, 01:12 PM | #2 |
Re: Pics? of 'Pump to carb' fuel hard line?
This is for a 72 C10. Do you have the wrong pump? There is a short and tall pump.
04-20-2020, 09:57 PM | #3 |
Guest
Posts: n/a
Did you change the intake manifold? If you did it could be part of the problem. An aluminum intake that is higher than stock will cause the line to come up short.
04-20-2020, 11:56 PM | #4 |
Old member
Buy the fuel line and bend it your self. Not that hard to do and will be a perfect fit.
04-21-2020, 01:49 AM | #5 |
My manifold is stock.
Wake328, is your fuel pump short or long? |
04-21-2020, 08:33 AM | #6 |
That is a short pump in his picture.
04-21-2020, 08:46 AM | #7 |
Flipped
This is the stainless line from right stuff auto detailing. If you are running the Q jet, there are a couple different ways the line can attach to the carb, manifold height (as already pointed out). Mine is the short pump, it originally had the long pump. The description for this line specifically said it was meant for the short pump. Fits perfect for the application it was designed for. I have had to give pre-bent lines some tweaking... but its worth it to me.... I hate bending lines. Last edited by wake328; 04-21-2020 at 08:55 AM. Reason: accuracy |
04-21-2020, 08:54 AM | #8 |
this is mine with the incorrect pump, the line did not reach (top to bottom) and the orientation of the fittings was different as you can see where the new line would be oriented. Ordered correct pump... perfect
04-21-2020, 10:23 AM | #9 |
All stock, 396, Quadrajet and AC Delco fuel pump. Stainless line from the Right Stuff, fit well.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
04-21-2020, 06:06 PM | #10 |
wake328, do you know what the part # was for that particular line?
04-21-2020, 06:12 PM | #11 |
Here's a couple pics of what I've got going. Can anyone tell if I have the short or long fuel pump? Also, my pump only has 3 fittings, not 2.
I'm running a stock quadrajet. |
04-21-2020, 06:12 PM | #12 |
aargh, they are upside down
04-21-2020, 07:30 PM | #13 |
If your truck has ac lines above wont work
I BELIEVE IN JOHN 3:16 |
04-21-2020, 07:39 PM | #14 |
No A/C.
Here's more pics. I have a right stuff tpc 7301 - meant for 73-80 small blocks with quadrajet. I thought this would be the right line because my motor and carb are a 75. It was close, but not it. Too short and wrong angle at fuel pump. I think I need either a tpc 7101 or 7002, but not sure...? |
04-21-2020, 07:54 PM | #15 |
That isnt a correct 72 f/p............... Just make one from 3/8 metel linen i just did...
# 8 PIC. IS CORRECT 72 PUMP
04-21-2020, 08:43 PM | #16 |
well whatever line you have there wake328, looks to me like it would fit perfectly on mine. our fuel pumps look real similar. Do you remember the part #?
04-21-2020, 11:41 PM | #17 |
04-22-2020, 12:13 PM | #18 |
thank you
04-22-2020, 02:23 PM | #19 |
Now, THAT is beautiful!
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Thread Tools | |
Display Modes | |
