Dynomat on in cab gas tank?
I was wondering if anyone has put sound deadner onto the tank to deaden the sound of it sloshing in the cab? And did it work?
Re: Dynomat on in cab gas tank?
Maybe I'm just old & deaf but I don't hear gas sloshing around in the in-cab tank in my '71 GMC. My truck has A/C & dual exhaust that exit at the rear corners of the bed.. turn down under the bumper. The noises I hear mainly are wind, road & exhaust noise that all increase with speed. Not bothered by SLOSHING noise though.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
I haven't had a running 67 for at least 6 years now but I seem to remember that at half full and on a right turn I cound hear the fuel swish around the tank. Maby my memory isn't correct. Anyone else have this and do this.
![]() Join Date: Apr 2016
I don't have anything covering my in-cab tank. Yes, I hear the gas sloshing around. I don't think I would do anything to reduce it, because I kind of like it. It's things like the triangle vent window, the 4 1/2 turn steering ratio, the tink-chew-tink-chew of turn signal flasher, the sound of gas sloshing around in a big tin, and the starting procedure for the carbureted engine, that remind me of the days when things weren't just a bunch of plastic. Makes me smile.
Yeah that's a good point.
I did this... first I sprayed it with sound deadener from The Eastwood co. and then covered it with Dynomat. I also did the cab floor and inside the doors. Makes a big difference.
#7 | |
![]() Join Date: Nov 2018
Dynomat does yield some sound insulation, but it is mostly to stop the vibrations of "loose and free" sheet metal. eg. Take a dummers cymbal and just put a piece of chewed gum on it somewhere...it makes a big difference. The gum dampens the cymbal's vibrations hence killing the sound. Your gas tank already has the chewed gum in it in the form of gasoline. A better solution would be closed cell foam, carpet, cardbaord, or even some bubble wrap. Adding dynomat to will help a bit, but not as much as some ohter things. Carpet would be on the top of my list to try.
Me...I dig the sloshing.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
I did when I put the material in my cab.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Thread Tools | |
Display Modes | |
