Old 05-11-2020, 07:04 PM   #1
Ohio mike
New key parts hood doesn't like my hinges
I got my hood today for my 67 from gmc pauls and it looks great, fits great. Stock key parts hood. One thing I don't like about it is rather than run foam across the entire hood between the rear hinge support and the hood skin they just put a blob on every 6 inches or so. The problem with that is when I pull the hood down it puts all the pressure on those spots as the hood flexes and puts outie dents in my hood. I think my hinges are shot and in my opinion it pulls down a little harder than it should, I will probably replace them. Has anyone had this problem and how did you fix it? New hinges? Billet hinges? Lighter hood spring? Run a good seam sealer entire width of hood to absorb pressure evenly? Any help is appreciated
Ohio mike is offline   Reply With Quote
Old 05-11-2020, 07:18 PM   #2
69Tom
69Tom's Avatar
Re: New key parts hood doesn't like my hinges
New hinges or have them rebuilt. You could try lubricating them to see if it helps some first.
69Tom is offline   Reply With Quote
Old 05-11-2020, 07:28 PM   #3
Ohio mike
I lubed them already.
Old 05-11-2020, 09:24 PM   #4
72 tigger
72 tigger's Avatar
Wondering if you could remove the springs and see if it closes properly? Just a thought
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 05-12-2020, 08:45 AM   #5
Ohio mike
I did yesterday. I think i will replace the hinges and try to remove the spots of sealer/foam and run a good bead across the hood otherwise it will keep pushing up on the spots. It didnt do this with the oem hood.
Old 05-12-2020, 10:27 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What is this "sealer foam"?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-12-2020, 12:49 PM   #7
Ohio mike
Originally they had a foam type seal between hood skin and supports underneath. You can use a urathane seam sealer now, something that stays soft and flexible.
Old 05-12-2020, 12:53 PM   #8
GASoline71
GASoline71's Avatar
You mean the anti-vibration foam strips wedged between the hood skin and hood frame? They don't seal anything.
Gary
Old 05-13-2020, 07:02 AM   #9
Sounds like the problem is in the blobs, not the hinges. I'd do whatever I could to place pressure evenly. Sounds like something Key Parts needs to hear about. They provide quality parts but it seems this method of using blobs is a bad idea. Do as GM did and you have a good part
Old 05-13-2020, 09:38 AM   #10
Curtb1971
Curtb1971's Avatar
We just ran into this same issue. The hood is made of thinner metal then the OE hood and the blobs put two outtie dingers when the hood would close. Made it better by removing the glue joints and bending the lip of the rear structural support down further.
https://youtu.be/TdUsyXQ8Wrs
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 05-13-2020, 10:00 AM   #11
Ohio mike
Thanks thats what i was looking for. I think the metal is suppose to be the same thickness but even so its taiwan metal and doesn't have the same strength. It is what it is, i will clean it up and get the support even across hood. Beautiful hood other than that, i wish I'd ordered a fender to I bet they fit decent.
Old 05-13-2020, 10:21 PM   #12
Yeah, Key Parts does in fact make their parts with the same gauge as OEM. Factory hood are known to bow. The reinforcement is very much needed and the anti-vibe needs to be continuous so as to not localize the support
Thread Tools
Display Modes
