Old 05-14-2020, 05:44 PM   #1
CJM72
72 Parking & Turn Signals
Hello All! I'm having issues with my front bumper mounted parking / turn signal lights in my 72 Blazer. Searched all over and most people just point back to the wiring diagram.
Symptoms:
Drivers Side bumper light and marking light turn on and off at the same time when the headlights are off. Passenger side bumper and marking light alternate. When the parking lights are turned on the both marker lights turn on and only the drivers side bumper light comes on. With the parking lights on, the drivers side bumper light no longer flashes when the blinker is turned on (stays lit)...passenger still flashes but no parking light.
My understanding is that the bumper lights should be on when the parking lights are turned on. I also believe that the bumper and marker light should alternate when the blinker is on. The front harness in this Blazer has been replaced and looks brand new.
Could I have the wrong bulbs in the bumper lights? Any pointers on troubleshooting this?
Thanks! Chris
CJM72 is offline   Reply With Quote
Old 05-14-2020, 06:18 PM   #2
SeventyOne
Re: 72 Parking & Turn Signals
How do the fender mounted marker lights operate? Same symptoms as the bumper blinkers lights?
SeventyOne is offline   Reply With Quote
Old 05-14-2020, 06:36 PM   #3
CJM72
I believe they are working correctly. They blink when the parking lights are off. They light up when the parking lights are turned on. Still blink when the turn signal is engaged.
Old 05-14-2020, 08:02 PM   #4
SeventyOne
Stock wiring harness?
This makes me think it's a ground issue on your bumper lights if the fender lights work correctly. They are tied together in the wiring.
I believe the brown wire controls the parking light and the light/dark blue control the blinking.
I have an American auto wire wiring kit in my blazer but it should be the same:
Name:  Screen Shot 2020-05-14 at 5.01.38 PM.jpg
Old 05-14-2020, 08:30 PM   #5
CJM72
Hmm. I think you might be on to something. I also think there might be 2 issues here. The drivers side parking light didn't light up until today when I was messing with the bulb and wiring. I could get the parking light to come on solid by moving the bulb around or touching the housing to the bumper, but nothing reliably. If both the bumper light and side marker are flashing at the same time, is the bumper light grounding through the side marker ground? How does the bumper light ground? Through the housing and bumper? I'm not sure how the alternating flashing works.
I'm wondering if my non functional parking lights are related to the wiring in the headlight switch. Could be wired up the pre 68 way and the parking lights are not getting power with via the light switch.
Guess I got some more messing around to do!
Old 05-14-2020, 08:48 PM   #6
CJM72
One more clue to offer. On my gauge cluster, when I turn the parking or headlights on, the left turn signal indicator lights up solid green. It will flash when the turn signal is turned on but after it will stay on. The right cluster indicator only flashes green when the turn signal is on.
Old 05-14-2020, 09:35 PM   #7
SeventyOne
I just re-read your original post...
Drivers Side bumper light and marking light turn on and off at the same time when the headlights are off. This sounds normal IF you are actuating them via the TSS.
Passenger side bumper and marking light alternate. Meaning you initiate the TSS for a right turn and the bumper light blinks on, and when it goes off the side marker goes on?
When the parking lights are turned on the both marker lights turn on and only the drivers side bumper light comes on. Yeah that's weird. Could be a ground issue. Or I had an issue once with my tail light bulbs where I had them installed wrong. The two prongs are offset so I could literally install them upside down. So....check your bulb.
With the parking lights on, the drivers side bumper light no longer flashes when the blinker is turned on (stays lit)...passenger still flashes but no parking light. See above. check bulbs. Sound like what was going on with my tail lights.
I also believe that the bumper and marker light should alternate when the blinker is on. No. Since the have the same feed from the wires they will fire at the same time. Both on and both off at the same time.
Old 05-14-2020, 10:48 PM   #8
CJM72
Thanks for your help SeventyOne! Got it fixed tonight. Ended up being a series of small errors. Passenger bumper parking light had a bad connection at the core support junction. One of the terminals was pushed back in the rubber connector. The bulb socket was also pretty corroded and needed a lot of cleaning.
Drivers side had some hack wiring on the parking light lead that had the high and low dual filament backwards. It also had a corroded bulb socket that I cleaned up and the ground to the bumper was also rusty. With everything cleaned up and rewired, it's all working well enough to go get a sticker!
Interestingly, the bumper and side marker blink in sync with the parking lights off, but alternate once the parking lights are turned on. It's working the same for both sides, so I assume that is correct. Must be a function of the dual filament bulb. Thanks again!
Old 05-14-2020, 11:28 PM   #9
SeventyOne
Glad to hear it - so yeah basically bad grounds and checking bulbs haha.
If the blinker and side markers alternate with the parking lights on maybe that's how it's supposed to be. I'll have to check mine!
Thread Tools
Display Modes
