05-20-2020, 02:58 AM | #1 |
Th400 help
So long story,short version lol, I have been restoring a 1972 c10 with the stock 402 and th400 for the past 8 years. Due to my divorce and having to move I am missing the bolts to transmission mount connecting it to crossmember and can’t seem to find any, so does anyone know the size of bolts and grade I should get, also is there supposed to be a plate between cross member and transmission mount if everything has stock brackets and mounts if so do you know where I can get one there was not one on this truck that I know of.
Thank you for your time |
05-20-2020, 11:13 AM | #2 | |
Re: Th400 help
My notes for the transmission mount are below, 402/400TH. See page 835 in assembly manual. Transmission mount to transmission crossmember: The transmission mount secures to the transmission crossmember using two (GR5) 5/8" hex bolts, washers and lock washers. The bolt threads are 7/16-14 x 1. The bolts insert from below. NOTES: One bolt is stamped "M" and the other a faint "C". The washers are 3/16" thick and 1.1/4" wide. Transmission to transmission mount: The bottom of the transmission mount is rubber and has two female threaded inserts. The transmission was mounted using two 3/8” shims (spacers) between the mount and transmission. The transmission was secured to the mount using two 5/8" hex bolts and lock washers. The bolt threads are 7/16-14. NOTE: The bolts weren't factory and varied in grade and length. Assembly order on the original mount from the bottom: Bolt > lock washer > mount > two spacers > transmission. NOTES: The mount was replaced with an Energy Suspension mount and (GR8) 7/16-14 x 1.1/4” bolts and washers. The mount sits the transmission 2" above the crossmember. The female threads in the transmission are approx. 7/8" deep. Per the transmission shop the bolt should insert at least 3/4" into the threads in the transmission. If they're too tall they'll damage the transmission.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-20-2020 at 11:38 AM. |
05-20-2020, 08:33 PM | #3 |
Re: Th400 help
thank you so very much, going to get them tomorrow after I get off work.
Thread Tools | |
Display Modes | |
