06-08-2020, 04:45 PM | #1 |
Best Disc Brakes (kit)
What are the best brake kits(or part #'s) that you can get for the 4wd 6 lug 67-72's that will fit into stock 15x8" steel wheels. While Wilwoods look cool, I've heard conflicting statements on their stopping ability for the price tag.
From what I can tell, there doesn't seem to be too many product offerings for performance brakes in a 15" wheel package.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
06-08-2020, 05:30 PM | #2 |
Re: Best Disc Brakes (kit)
While I don't have Wilwoods, I do recall reading that the OEM 1/2 single piston design offers larger surface area than the wilwoods dual piston design. Which is why they don't brake as well as stock calipers.
for 6 lug brakes I'd wager stock calipers are going to be your best bet. For me personally it wasn't going to cut it with my lift and large tires so I went 8 lug 3/4 ton brakes which have a larger rotor and the caliper pistons are slightly larger as well. Then I put on a hydraboost setup. |
06-08-2020, 07:45 PM | #3 |
Many swap the entire front diff out. Disk brakes started in 71 and Blazer and Suburban half ton diffs can swap up to 91.
06-09-2020, 07:18 AM | #4 |
I made my own from OEM parts. Uses the large late model rotors and late model 4 piston calipers. It all fits in a stock 15” rim also. If you have machining abilities, I can explain how. The brakes work excellent and way superior to the original. The best part is that everything fits on a stock drum brake hub so you can convert an original drum brake front axle to disc . If I recall, I have pics on my build thread.
Posted via Mobile Device |
06-09-2020, 02:02 PM | #5 | |
06-09-2020, 08:05 PM | #6 |
06-09-2020, 10:16 PM | #7 | |
06-10-2020, 09:28 AM | #8 |
I used 2003 calipers with mid 90's rotors. The backing plates are made from 1/4" plate. Obviously the backing plates need to be custom machined, but also the mounting hole on the rotors needs to be opened up a bit to fit the Blazer hub. Also, to get it to fit in a 15" rim, the bottom of the pads need to be clearanced. I also used a 2003 master cylinder, but planning on changing that out one of these days. the 03 master cylinder has a 1.250" bore, and it make the pedal too hard for my liking. It all works great but I want to go down to a 1.125" bore master. It's an easy swap, but as I said you will need to machine stuff.I have almost 20000 miles on it now and it stops like a late model truck. For liability reasons, I cannot make these to sell.
06-10-2020, 09:43 AM | #9 |
This is the only pic I had of the back plates, but will give you an idea how the calipers mount.
06-12-2020, 06:43 PM | #10 |
i dont know which are the best kits, but my hydra boosted system dang near put me into the windshield with 35s and stock calipers
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
06-13-2020, 04:14 PM | #11 |
06-13-2020, 11:16 PM | #12 |
Following ...
06-15-2020, 10:03 PM | #13 | |
06-15-2020, 10:07 PM | #14 |
I've heard lots of great things about hydroboost. Did you do a thread writeup on your hydroboost system swap? If so, would you be able to include the link in this thread so it can be referenced in the future?
06-16-2020, 05:30 PM | #15 | |
I've had a lot of PMs requesting info on what I used, so I'm hoping in the next few days to post part numbers of everything. Hopefully the OP won't mind if I do this on his post. |
06-16-2020, 06:07 PM | #16 | |
06-16-2020, 08:34 PM | #17 | |
Thread Tools | |
Display Modes | |
