06-16-2020, 06:09 PM | #1 |
I hate wiring
Hey guys, working on the 68 trying to get it back on the road and I’ve ran into a problem. I have headlights and hazards, but no tail, brake, or reverse lights. I unplugged the rear harness from inside the cab and ran a jumper to the rear harness and they worked. I also checked for 12v on the orange wire on the backside of the fuse box and there is none. I’m an idiot when it comes to electrical so I have no idea what this means, any help is greatly appreciated!
06-16-2020, 06:18 PM | #2 |
Re: I hate wiring
Try attaching one end of a ground wire to bed sheet metal and other end to the frame, worked for me.
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
06-16-2020, 06:22 PM | #3 |
Re: I hate wiring
I’ve added about three extra ground straps throughout and just to make sure it wasn’t that, I ran a ground straight from the battery to the tail lights. My brain is exhausted from this
06-16-2020, 06:33 PM | #4 |
Re: I hate wiring
So if I’m understanding this correctly, if I have no power at the orange wire on the back of the fuse box, does that mean the orange wire contact on the back side of the box is dead?
06-16-2020, 07:31 PM | #5 |
Re: I hate wiring
Most likely means the TAIL STOP fuse is bad, or the contacts holding the fuse are corroded. I suggest use a test probe or multimeter to check for voltage on both sides of the fuse.
If you ran jumpers and it worked, it sounds like you're making progress. |
06-16-2020, 07:35 PM | #6 |
Re: I hate wiring
I used a multimeter on it and have 12v on one side of the fuse, but not the other. The fuse is new
06-16-2020, 08:36 PM | #7 |
Re: I hate wiring
Where were the multimeter probes touched, on the metal ends of the fuse itself or on the clip that holds the fuse on each end? If on the metal ends of the fuse itself, that means it is a bad fuse. If on the clip that holds the fuse, probably corrosion on the clip.
06-16-2020, 08:43 PM | #8 | |
Re: I hate wiring
06-16-2020, 09:22 PM | #9 |
Re: I hate wiring
If the fuse looks good but tests bad, that is probably a manufacturing defect. If it is blown, it could have been instantly blown when you touched the brake pedal the first time after installing the fuse, because you have a short somewhere.
06-16-2020, 09:40 PM | #10 |
Post Whore
Re: I hate wiring
It is not uncommon for the back of the fuse block to get corroded and lose conductivity. The metal tabs that hold the fuses in place are riveted to the bus work (or individual wires) and those rivets are what make the connection tight. When corrosion gets in between the rivet and the metal parts conductivity is lost or voltage drops too low to operate a small load like a taillight.
By checking to each individual metal piece of the fuse holder you can locate where the voltage is lost. Basically you will need to start at the last known location of voltage and test every single connection. Now an easier way to do this is to put your meter leads on each side of the connection and check for DC voltage. If you find ZERO volts the connection is good. Like putting your positive meter lead on the battery positive post and the negative meter lead on the positive battery cable clamp. A good solid connection will drop no voltage so no voltage can be detected with your meter. Now if your meter reads some voltage then there is a problem. The higher the voltage you detect the higher the resistance of the connection and the more voltage is lost. For example If you have a connection like the one the red arrow points to (Photo below) and one lead is on the rivet and one lead is on the silver bus piece next to it and your meter indicates 3.2 volts. That means the voltage will drop 3.2 volts there. So If your battery voltage was 12.5 volts all the circuitry after that point would only be 9.3 volts. If one other connection drops 3.5 voltage it will keep your lights from lighting. This problem of voltage loss is not limited to the positive side of the wiring. Every poor ground connection contributes to the voltage dropping. How many ground connections are between the negative battery post and a taillight bulb? 2? 3? 5? These connections could also have been damaged by an overheated circuit in the past like some of the ones shown below. I harvested this photo from a post VetteVet posted (Thank you sir) and added the arrows to help show problem areas. Green arrow rusty connection possible voltage drop where wire is crimped into the metal tab. Red arrow overheated connection. Notice blackened rivet it has been very hot in the past. Expanding with the heat it deformed and now may be loose. In addition the heat burnt off any anti corrosion coating and it is vulnerable to corrosion. Blue arrow damaged wire that has been repaired. Properly? You wouldn't know until you took it apart. Here is the thread where I got the photo from. And once again thanks to our wonderful newly promoted moderator VetteVet! http://67-72chevytrucks.com/vboard/s...968+fuse+block
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-17-2020, 06:32 AM | #11 | |
Re: I hate wiring
06-17-2020, 12:12 PM | #12 |
Re: I hate wiring
Do you have the OG turn signal switch? Did you mess with it?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-17-2020, 02:26 PM | #13 |
Re: I hate wiring
06-17-2020, 02:51 PM | #14 | |
Re: I hate wiring
Found melted wires in the intermediate wiring to the rear. Bad fuses, bad turn signal relay, and dirty connections in the bulkhead connection and turn signal switch. Did all this in 1-2 hour sessions over the course of 2-3 weeks so I didn't lose my feeble mind.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-17-2020, 05:24 PM | #15 | |
Re: I hate wiring
Thread Tools | |
Display Modes | |
