Old 06-28-2020, 11:45 AM   #1
CG
BlahBlahBlah
More dually wheel questions.
First off I just realized I’m woefully short on lug nuts. Ideas on where to get this kind?
Secondly I have no real idea on the reasons for these rings. The tires I purchased are of a size I should not need any sort of spacer between the rims to avoid the rubber rubbing against each other. Also these nubs? My new steel 16 inch rims have no provisions for them. Ideas on where to get these rings?
I’m new to the dually world and apparently I’m a crappy google searcher because I’m missing the info out on the www. Thanks for any help.
Old 06-28-2020, 01:43 PM   #2
HO455
Post Whore
HO455's Avatar
Re: More dually wheel questions.
Here is the answer to your wheel ring question.
http://67-72chevytrucks.com/vboard/s...al+wheel+rings
RIP Bob Parks.
Old 06-28-2020, 06:46 PM   #3
CG
BlahBlahBlah
According to that info (if Im reading it correctly) the lug nuts I have so far negate the reason for having the rings.
Old 06-28-2020, 07:17 PM   #4
68bowtie
68bowtie's Avatar
According to my notes as long as your wheels have a 4.56" hub diameter, they will bolt up to pre-2001 hubs with the flat-faced lug nuts you have. Hub-centric. No need for the clamping (alignment) rings. As I was learning this, I took a close look at my P30 19.5" wheels, which had a nice tight 4.56" hub bore, and fairly sloppy lug openings. So you don't need the clamping rings, and you don't want acorn nuts.
Here are my notes (no guarantees lol!):
- my 19.5" wheels: 4.56" bore, 0.53-0.58" bolt holes (not perfect)
- Lug info: -70 drums and 1/2-20 lugs, 71+ discs and 9/16-18 lugs
- Axle info: -2000 4.56" hubs, 2001+ 4.60" hubs
- Lug nut info: all have flat washer lug nuts and hub-centric, or can use cone nuts and clamping plates
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 06-28-2020, 07:28 PM   #5
68bowtie
68bowtie's Avatar
Oh, and yeah I believe your statement is correct. They are harder to find, but you should have some luck looking for "flange" lug nuts.
Old 06-28-2020, 07:33 PM   #6
Mike C
Mike C's Avatar
Alcoa sells them for their dually rims. I bought 32 of them for my K30. They were/are expensive at like $6 each when I got them.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-28-2020, 11:29 PM   #7
CG
BlahBlahBlah
Ill start a search for a set of lug nuts. Ill see if I can come up with a full set of 32, hopefully at a better price than six bucks each (ouch haha) ... Thanks for all the info guys.
Old 06-29-2020, 08:45 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: More dually wheel questions.
I ordered a set of these lug-nuts for the 86 front end which is the factory nut for the Ramp truck front wheels so I can install the hub caps I bought.
These where $1.99 each off the website.
O-Rielly's wanted $5.00 each.
http://www.ezaccessory.com/Specialty_Lug_Nuts_s/24.htm
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Thread Tools
Display Modes
