12-14-2003, 03:43 AM | #1 |
Stylin
vaccum gauge
how would a vaccum gauge help u out? I'm just wondering as to im getting one for free and it matches my other gauges and id like to fill the hole where the clock went with something other than a fuel pressure gauge that isnt hooked up. i also ordered a mech. oil pressure gauge cause im sick of it just being pegged out a little farther then 60 when im crusing and just seeing about 30 at idle lol. but anyways how would one benift me?
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
12-14-2003, 03:52 AM | #2 |
Professional Grade
Good way to tell if you suddenly get a vaccume leak, lol -- There is also the coolness factor of it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-14-2003, 03:58 AM | #3 |
Stylin
well my other gauges are of this type. the only ones left stock are my speedo and my gas gauge. and ill probally replace those and buy a tach to put in the place of the gas gauge and get a small gas gauge and put it on the pillar.
12-14-2003, 04:10 AM | #4 |
Professional Grade
Why don't you get a small gas gauge to put into the place where you are thinking of putting the vaccume gauge in?
12-14-2003, 04:12 AM | #5 |
Hotwheels?
I have a vaccum gauge in mine. It helps, if you have really low vaccum you know something is wrong. its also another reference point, I always know I have about 16" of vaccum @ idle in drive. Its just nice to get everything perfect. And it definitely gives conversation...
Whats that? Vaccum gauge... Whatsit do? Lemmie tell you...
1978 Money Pit - CUSTOM DELUXE!!!! |
12-14-2003, 04:15 AM | #6 |
Stylin
lol so where would i hook it up? i know ive got low vaccum at the back of the intake at start up till it warms up
12-14-2003, 09:51 AM | #7 |
You can hook up the vacuum gage anywhere you can get full vacuum from. Manifold, carb.
12-14-2003, 04:22 PM | #8 |
Hotwheels?
Mine is to my carb on fulltime vaccum advance, I have a T splitter for it. I mounted it in one of the AC vents in the middle. I plan on putting 2 other gauges in there to finish the hole up. Dont know what gauges to put there though.
12-14-2003, 04:22 PM | #9 |
You get what you pay for
I've got one in my truck. To tell you the truth, it's not worth much, except for having another gauge too look at. No real useable info. A lot of folks will say you can use it to save fuel by keeping your vacuum as high as you can. Yeah, right.
If you have one and somewhere to put, I say go for it. But for sure, it's not going to do much for you as far as performance or keeping track of engine condition. Sure, if you have really low vacuum it will tell you, but you will know this way before you ever notice it on the gauge. I never look at mine. Just a another big waste of money as far as I'm concerned. But hey, so is 99% of the stuff on my truck.
Mike 1985 Chevy C-10 |
12-14-2003, 04:29 PM | #10 |
Hotwheels?
Another "COOL" mod. Doesnt do much, but looks good
12-15-2003, 05:50 PM | #11 |
Vacuum gauge can give good indication of how your engine is running/operating. Its just another tool to monitor your engine.
You can use a vacuum gauge to tune your carb. but it would be hard to see if your under the hood and its inside. Get one of these instead for $70
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
12-15-2003, 06:04 PM | #12 |
I have a Mityvac set. A great tool to have in your collection for sure.
12-15-2003, 06:14 PM | #13 |
Stylin
well i got this one for free and i have one that connects to the carb already
12-15-2003, 07:17 PM | #14 |
Stylin
ok where would i hook up my vaccum gauge at on an edelbrock performer carb? ive got the pcv, the vaccum advance and then i forget where the other one goes 2
12-15-2003, 07:42 PM | #15 |
It needs to hooked straight to manifold vacuum Find a hose coming from the intake and tee into this hose.
12-16-2003, 12:00 AM | #16 |
Stylin
ive got a 3way vaccum tree at the back of the intake and 2 holes are plugged do i just hook it up to that?
12-16-2003, 12:14 AM | #17 |
Should work just fine as long as it's got full vacuum at idle.
12-16-2003, 12:14 AM | #18 |
yes
can the mityvac setup be used to bleed brakes? i HATE bleeding brakes, and that would be perfect for eliminating that problem if it will work. |
12-16-2003, 12:17 AM | #19 |
Right turn Clyde
yep they are pretty nice for bleedin out the brake lines.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
12-16-2003, 12:21 AM | #20 |
Stylin
its the only vaccum port i saw on the intake
12-16-2003, 12:30 AM | #21 |
The Mityvac works great bleeding brakes. It works for anything requiring vacuum. It will also work the other way and put pressure on things.
Everyone needs one of these sets. One of the best tools you will have. You can check things that work off vacuum for leak down. Check the vacuum advance to see how much advance you have and the amount of vacuum required to start it, etc. Just an all around great tool. No one who does tuning or vacuum work in general should be without. |
12-16-2003, 12:32 AM | #22 | |
Just unhook it while the truck is running at idle and see it's it's sucking air. |
12-16-2003, 12:48 AM | #23 |
Stylin
its running vaccum to the modulator on the trans.
Thread Tools | |
Display Modes | |
