Old 08-20-2020, 06:06 PM   #1
underliner6
underliner6's Avatar
Carb Adapter Help!
Hi guys,
I put a Holley Sniper on my truck. I love it but I am having issues figuring out what kind of adapter I need between the Sniper and my Intake manifold. The engine is a Goodwrench 350. When I install the Sniper and carb spacer or just the Sniper alone, a small gap is exposed up front which sucks in air. While the truck is running the intake will suck hard on your finger if you block the gap. I’m sure this is negatively affecting the system because the Sniper is compensating for an intake leak.
Can anyone direct me to which adapter I need for my given intake manifold? I ordered an Edelbrock 8716 but it’s not the right one.
Thanks for any help.
Jim
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
1971 K5 Blazer
underliner6 is offline   Reply With Quote
Old 08-20-2020, 06:36 PM   #2
bigmac73
bigmac73's Avatar
Re: Carb Adapter Help!
you need a spread bore to standard Holley 4 hole
https://www.summitracing.com/parts/edl-2696
take a look at this
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-20-2020, 06:40 PM   #3
bigmac73
bigmac73's Avatar
https://www.summitracing.com/search/...-bore-4-barrel
or this
Mike
Old 08-21-2020, 10:17 PM   #4
underliner6
Originally Posted by bigmac73 View Post
Perfect! Thank you very much!
Jim
1971 K5 Blazer
Thread Tools
Display Modes
