09-09-2020, 04:25 PM | #1 |
Leaf Springs for C30 with Dana 70HD
I currently have a 1972 C20 upgraded to C30 with an LS engine and an NV4500 transmission. All corners have been updates with hubs, brakes and differential of a 1989 or 1998 C3500 pickup. The current leaf springs is a 4 plus 1 spring and it's too soft the empty steel bed. I need something stronger.
I plan to do some heavy towing. Will the DAYTON 22419HD (4100 lb) be an overkill or should I opt for the DAYTON 22419 (3390 lb)? Is the weighted rate per side or for both sides together? I already have 5000 lb air bags but I can't rely just on the air bags to carry all that weight. Thanks!! Last edited by Aruba1; 09-09-2020 at 04:38 PM. |
09-10-2020, 09:07 AM | #2 |
Re: Leaf Springs for C30 with Dana 70HD
I just bought new leaf springs and they were labeled 3000 lbs per pair
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
09-10-2020, 11:10 AM | #3 |
09-10-2020, 12:00 PM | #4 |
you'll still have (theoretically) a 3/4 ton with heavy axles. In the long run, the frame, still can only handle so much. 1 ton frames are massive.
Thread Tools | |
Display Modes | |
