09-23-2020, 06:37 PM | #1 |
How to fix this bolt hole
I recently removed the left door panel and discovered one of the 'nut' inserts is gone. I've thought about how to fix this but, haven't really come up with a good solution. I thought about trying to take a nut of correct size and grind it down a bit on 4 sides to a 4 sided configuration and epoxy glue it in. Anyone ever fixed this same problem?
09-23-2020, 07:37 PM | #2 |
Re: How to fix this bolt hole
Not sure what size it is, but you might be able to find a nutsert to fit in the square opening.
09-23-2020, 07:44 PM | #3 |
I have a 1969 truck and had a similar situation. I had 1 or 2 of the nuts on the door come off when I was used some force getting the bolt out. I replaced the nuts with 1/4-20 cage nuts from the hardware store. I don't know if that will work for you on the 65 but it kind of looks like it will.
A nut that survived A cage nut |
09-23-2020, 08:23 PM | #4 |
Moderator
Quick and easy: use a nylon license plate mount. From any parts store.
09-24-2020, 10:36 AM | #5 |
It's Better With Nitro
On a few of mine, I drilled them out an insalled the correct size nutsert.
09-24-2020, 02:14 PM | #6 |
Thanks to all for the replys!
09-27-2020, 09:45 PM | #7 |
09-28-2020, 11:52 AM | #8 |
I vote for these. They will never rust.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-28-2020, 04:56 PM | #9 |
Moderator
And, the answer for "what thread goes in there" is "yes"... lol
09-29-2020, 04:00 PM | #10 |
Well, I checked on both the plastic license plate insert and, the metal clip nut to fix the bolt hole. The plastic insert was for a #8 or #10 screw and wasn't compatible with a 1/4x20 bolt. I could get a metal clip but would have to purchase 25 of them. So I ended up using a square nut with 1/4x20 threads. I had to slightly enlarge the hole with a small file and, made it a snug fit. I left about 1/16th of the nut sticking thru to be able to get a good weld on it. It doesn't look as good as I wanted it to but, it's covered up by the door panel. I started cleaning it up with my 4" grinder and, it was too big. That's why you see the gouge in the door. Ended up using my dremel to finish it. I put a quick coat of primer on it and replaced the panel. Only took me about 15 minutes from start to finish.
Thread Tools | |
Display Modes | |
