09-24-2020, 02:56 PM | #1 |
What master cylinder do I have?
Looking for some help. My master cylinder went out this past weekend. I had bought a kit when I added disc brakes and need to replace the master but don't know what to buy.
09-24-2020, 05:33 PM | #2 |
Moderator
Re: What master cylinder do I have?
4 wheel disc or front disc?
1” bore or a 1-1/8” bore master cylinder? Where the rod from the booster goes into the master cylinder is it deep or shallow?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-24-2020 at 05:38 PM. |
09-24-2020, 06:49 PM | #3 |
Sorry, front disk, rear drum. I'm unsure of the bore size. I didn't check before I installed it a few years back. Just hoping someone recognizes the housing. I may be wrong but, I think I could use either bore size even if it's 1" I can go to 1 1/8.
09-24-2020, 06:56 PM | #4 |
Moderator
The housing is basic you can get them anywhere. POL, CCP, Speedway, Summit. However if you have a deep or shallow pin/rod out of the booster and change it...
Also if you change the bore it will be a change in brake response. You can removed it pretty easy and check before you buy it twice - Like my wife accuses me of doing.
09-24-2020, 07:18 PM | #5 |
Thanks. I was thinking of just buying one for a 72 C10 with disk brakes unless somebody has a better suggestion. My wife thinks I do the buy twice thing as well...
09-24-2020, 09:27 PM | #6 |
pretty sure its the same as an older corvette
09-24-2020, 10:06 PM | #7 |
60-66 Nut
That is typical of a '77-'82 Corvette which is what all of the aftermarket suppliers of the booster and master kits use. But could also be the '68-'76 Corvette with the deep bore in the back of the piston. You really should pull it off and see what the bore is in the back of the piston.
09-24-2020, 10:42 PM | #8 |
Thanks everyone, I'll pull it off. Knowing that it is the same as a corvette one I'll know where to start.
09-25-2020, 07:47 AM | #9 |
Moderator
You dont have to remove the brake lines. Just remove the two bolts that attach it to the booster, pull it toward the front of the truck slowly and take a look and the depth, then measure the bore. Put it back. I've done it.
09-25-2020, 02:31 PM | #10 |
Moderator
But... if it's Corvette, it's for four wheel discs.
09-25-2020, 04:03 PM | #11 |
Moderator
Maybe if he has a disc/drum proportioning valve it will help.
09-25-2020, 10:03 PM | #12 |
60-66 Nut
Everyone that sells those booster and master conversion kits, supply a Corvette master for both disc/drum and disc/disc brake systems.
Thread Tools | |
Display Modes | |
