Old 10-23-2020, 07:09 PM   #1
18Z
18Z's Avatar
Brake Line Diagram
Does anybody have a good brake line diagram for 64? We are doing a CPP disc conversion for the front, original drums on rear. We don't have the old lines for reference.
Thanks in Advance
18Z is offline   Reply With Quote
Old 10-23-2020, 09:31 PM   #2
MT65
Re: Brake Line Diagram
Are you trying to make it look completely factory?.
MT65 is offline   Reply With Quote
Old 10-23-2020, 09:45 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
You doent need the RPV's:
Old 10-23-2020, 09:47 PM   #4
The Rocknrod
Moderator
And if your using one of these under the master cylinder you dont need the APV:
Old 10-23-2020, 11:25 PM   #5
18Z
18Z's Avatar
MT65, no it doesn't have to be factory but I got a set of inline tube pre bent lines but the fronts don't look like they would go in a logical place, so i'm just checking to see if anyone had a diagram because there is not one with the lines.
Old 10-24-2020, 05:02 AM   #6
The Rocknrod
Moderator
By the time you get through straightening the inline tube pre-bent lines and trying to figure it out, you'd be money ahead making your own.
Old 10-24-2020, 07:46 AM   #7
kens65fb
With disc's up front, do you still need a residual valve for the rear lines ?
kens65fb is offline   Reply With Quote
Old 10-24-2020, 07:47 AM   #8
The Rocknrod
Moderator
Not if the master cylinder is in the stock position. If it's under the floor yes.
Old 10-24-2020, 08:22 PM   #9
MT65
Guess thats why I always just make my own, then I can put them where I want them, good luck, it’ll work out...
Thread Tools
Display Modes
