10-31-2020, 02:52 PM | #1 |
Diesel bell housing?mehcanical clutch rod on hydro assembly?
Ok so I've been searching all morning and cant find a solid answer.is there a difference in diesel and gas bellhousings?
I've read you can convert a mechanical pedal assembly to hydro, but can you go the other way around?not trying to be unique,just trying to use what I have.i found a pedal assembly for $20.it didn't seem right that it was taken apart,but for $20,I figured take a chance.turned out I bought an automatic setup with the brake and clutch pedal thrown in the box.not a big deal.i made it work. So I'm wondering if it's possible to hook up the mechanical push rod to the hydro pedals? (Also it looks like they used the pedal assembly for scrap.it had a huge chunk taken out.) Last edited by pat english; 10-31-2020 at 02:59 PM. |
10-31-2020, 03:05 PM | #2 |
Re: Diesel bell housing?mehcanical clutch rod on hydro assembly?
Also, what is the hole on the top of the pedal assembly for?I tried to make an arrow with my fat fingers..
(My friend had his pedal assembly out so I was able to take measurements to modify my automatic setup) |
10-31-2020, 03:28 PM | #3 |
Moderator
The AMG 6.2L & 6.5L diesel and Chevrolet V8 gasoline bellhousings use the same Corporate GM engine to bell bolt pattern.
There are several transmission to bell bolt patterns.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-31-2020 at 03:36 PM. |
10-31-2020, 03:44 PM | #4 | |
Any difference in the starter area?I read you have to grind something for the diesel starter to clear? |
10-31-2020, 06:22 PM | #5 |
Moderator
The Delco 27MT AMG diesel starter is significantly longer than the gasoline engine starter and the nose is not the same.
I doubt you can bolt a 27MT to a gasoline engine with the diesel nose and Bendix.
And please let us know if and how your repairs were successful. |
Thread Tools | |
Display Modes | |
