Old 11-01-2020, 02:17 PM   #1
FL71C10
Painting new dash pad - Landau black or Satin black
I am repainting a green dash pad that I bought for another truck to match my black interior. I bought both landau black and satin black sem paint. Does anybody have any experience with either of those and have a recommendation on which one would look best?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-01-2020, 04:35 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Painting new dash pad - Landau black or Satin black
Landau Black is my choice.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 11-01-2020, 06:23 PM   #3
FL71C10
I sprayed a sample of each on an old visor that I have and I'm waiting for it to dry to see how they compare. They both look pretty flat. We'll see how they look once they dry
Old 11-01-2020, 07:32 PM   #4
FL71C10
Well the paint is dry on the samples and I'm not sure I can tell the difference. In fact I'm not sure either one is shiny enough. Here's some pictures but I know they won't show up very well.
Old 11-01-2020, 10:49 PM   #5
LS short box
What other vinyl do you have in the truck? Seats or door panels. I would choose the color that matches best as it can.
LS short box is offline   Reply With Quote
Old 11-01-2020, 10:53 PM   #6
FL71C10
I'm not trying to match the color, I'm trying to match the glossiness of the original dash pad
Old 11-01-2020, 10:56 PM   #7
FL71C10
It's a red truck with gray seats and black metal door panels
Old 11-01-2020, 11:08 PM   #8
Astro-Balls
If you want a Gloss Black, use this..
https://www.amazon.com/SEM-15233-Glo.../dp/B002XMWA38
Old 11-02-2020, 04:41 PM   #9
FL71C10
I'm going to pick up a can of that this afternoon and try it tonight. I am tempted to just sell the dash pad and get a new black one...
But this way I can touch it up if it gets scratched which I couldn't as easily do with the black vinyl.
Old 11-02-2020, 08:41 PM   #10
jocko
jocko's Avatar
That's what I would do New ones aren't very expensive and even if you sold the green one at a discount so someone would jump on it (I assume it's never been installed), then you might end up at about the same net cost as buying all the SEM paint to do the color change. Or, just hang onto the green pad, you never know when you'll need it...
Old 11-04-2020, 09:49 AM   #11
FL71C10
Okay so I got the SEM gloss black and tried it on the visor and here are the results
Old 11-04-2020, 09:52 AM   #12
FL71C10
So, it is fairly shiny. I'm disappointed that there's no satin or semi-gloss finish. The other two are essentially flat. I'm going to go ahead and buy a new dash pad and sell the green one but I just thought people here might be interested in seeing the results of the comparison. Here's another couple of pictures of the landau and the satin in a little bit better light.
Old 11-04-2020, 10:13 AM   #13
j_cst_10
j_cst_10's Avatar
The sheen of the paint is very dependent on the surface smoothness below it. I have sprayed door panels that had different textures based on wear and what have you, it is glossy over the smooth portions and flat over the rougher portions. It doesn't fill in like paint.
I have painted smooth vinyl with the SEM semi gloss and it is glossy.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 11-04-2020, 03:51 PM   #14
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
It will change when you use a leather conditioner. It will then put a sheen to it that you are after.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Thread Tools
Display Modes
