Old 11-02-2020, 06:12 PM   #1
ssjody
GM 14 Bolt Carrier type ID help
My 68 K20 has a transplanted 14 bolt GM Corporate axle assembly in the rear. The seller told me it had a 4.10 ratio but I wanted to be sure so I pulled the cover. It does have a 4.10 but I'm not clear if this is a limited slip, locker or open carrier. Can someone educate me on what type this is.
ssjody is offline   Reply With Quote
Old 11-02-2020, 06:13 PM   #2
ssjody
Re: GM 14 Bolt Carrier type ID help
Well the pic's didn't work. I'll work on that
Old 11-02-2020, 06:55 PM   #3
kwmech
4 pins is an open carrier and 3 is a gov-loc. 4 pin could have a detroit installed, but you'd know that by driving it
Old 11-02-2020, 07:07 PM   #4
Richard2112
Richard2112's Avatar
My c30 has the same setup but it's geared in 373. Still don't know what that type of carrier is called
Richard2112 is offline   Reply With Quote
Old 11-02-2020, 08:20 PM   #5
kwmech
Just a standard open carrier...splits in half when unbolted...little more convenient.
Just a heads up for those that do not know......if you split the case, look for a witness mark on the edge of the carrier that tells you where to align the unit when reassembling
Old 11-03-2020, 12:23 AM   #6
57taskforce
All about them K’s
57taskforce's Avatar
This, I’ve got 2 14 bolts opened up right now on the shop floor because of a disk brake mod I’m doing. Both are open carriers just like the one pictured. You can look into the little windows and see there’s just spider gears and nothing else in there.
Tyler
57taskforce is offline   Reply With Quote
Old 11-03-2020, 06:05 AM   #7
ssjody
That was the conclusion I had come to. I seen nothing that made me think any different. Thanks!
Old 11-03-2020, 02:26 PM   #8
chevy71super
Curious. What is the function of the bolts in the middle of the bearing caps?
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 11-03-2020, 02:55 PM   #9
kwmech
If you look close, you can see a large u shaped large wire that goes into the adjusting nut and keeps it from moving
Old 11-03-2020, 03:23 PM   #10
chevy71super
Awwww. Thanks.
72 Cheyenne 4X4 SB
Thread Tools
Display Modes
