11-05-2020, 11:02 AM | #1 |
Flush Tail Lights?
Seen These On a Few Build Pictures. How Is This Done?
Posted via Mobile Device |
11-05-2020, 12:10 PM | #2 |
Re: Flush Tail Lights?
With no visible tailgate, it appears they have custom made the rear to be one solid panel. Then, cut in the taillight housing to fit. That's my rookie take on it.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
11-05-2020, 12:56 PM | #3 |
I Heard Guys Make Them Outta Plexi-Glass But Not Sure How
11-05-2020, 12:59 PM | #4 |
The body lines are already there, so remove all the trim and weld up the holes. Adjust tailgate gaps to be as small as possible and weld shut. Bumper delete panel, pretty standard there. Now you just need a custom plexiglass lens.
https://m.youtube.com/watch?v=Axo_bTyl1gQ Last edited by Dr Jekyll; 11-05-2020 at 01:22 PM. |
11-05-2020, 03:16 PM | #5 |
I agree. There's no texture to the lens, so it's just plexiglass (or maybe an acrylic, like Lexan). Shape it and figure out how you want to attach it and you're done. However, it may not be street-legal in your state. Most states require a minimum reflective surface to the rear.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-05-2020, 04:20 PM | #6 |
Right On!
I ll See If I Can Find Out How The Custom Lenses Are Made and Attached. Might Be Tricky |
11-05-2020, 05:43 PM | #7 |
This video shows various ways to cut acrylic/plexiglass
https://m.youtube.com/watch?v=Axo_bTyl1gQ After you get the shape of the lens, drill holes to line up with the tail light housing. Then you can use screws to attach the lens. I would counter sink the screw holes, wet install counter sunk screws with clear silicone sealant , and paint the screw heads black. To counter sink the screw holes use a slightly oversized drill bit or dremil grinder at high speed. That is how I would attempt this look, and it’s all hypothetical. I don’t have any experience with plexiglass/acrylic. I have done the counter sink screw thing though, that works perfectly. |
11-05-2020, 06:12 PM | #8 | |
Old member
A lot of elbow grease and body work.
11-05-2020, 08:07 PM | #9 |
I've worked with Plexiglas and Lexan extensively. I would use a bandsaw, if you have one. A jigsaw would work as well. As far as the countersink, you want to go slowly, rather than high speed. Plastics melt under high speed. Lexan and Plexiglas are soft enough that you can use a wood countersink bit with them.
Thread Tools | |
Display Modes | |
