Old 11-11-2020, 04:47 PM   #1
pjmoreland
pjmoreland's Avatar
Wandering Speedometer Needle at Highway Speeds
At speeds under about 40mph, my speedometer is stable, but it drifts around at higher speeds, as seen in this video:
https://youtu.be/5TxuNPqF8_g
I swapped in another speedometer I had, and it was even worse, but acted basically the same way. It seems like bumps in the road are causing the needle to move around. What can I do to fix this? Do I need to get a new/reproduction speedometer?
pjmoreland is offline   Reply With Quote
Old 11-11-2020, 05:24 PM   #2
LS short box
Re: Wandering Speedometer Needle at Highway Speeds
Try lubing the speedo cable. Doesn't cost any thing and it may help.
LS short box is offline   Reply With Quote
Old 11-11-2020, 05:28 PM   #3
pjmoreland
pjmoreland's Avatar
I did lube the speedo cable last night and it had no effect. It is a new cable, although the speedo acted the exact same way with the old cable.
Old 11-11-2020, 07:25 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wandering Speedometer Needle at Highway Speeds
Take the cable loose at the transmission and look at the plastic gear head it goes into. It's more than likely worn out. Take it out and buy the same gear put back in it. This is just example picture. Look into the end opisite of the gear that is where the cable goes. It should be nice and square like the cable and fit's pretty tight.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-11-2020, 07:54 PM   #5
pjmoreland
pjmoreland's Avatar
Here's my gear. It's a 44-tooth out of a TH400. Looks pretty good to me, but I will replace it anyway
Old 11-11-2020, 08:33 PM   #6
Andy4639
Old member
Andy4639's Avatar
That gear looks OK. It could be the end of the cable that goes into the speedometer head also. Are the cable end going to the gear itself. How do they look?
Old 11-11-2020, 09:38 PM   #7
pjmoreland
pjmoreland's Avatar
The cable ends look perfect to me. Here are some mediocre photos of them.
Old 11-11-2020, 10:06 PM   #8
HO455
Post Whore
HO455's Avatar
If he doesn't chime in PM TBONE1964. He will be able to talk to possible problems inside the speedometer itself.
RIP Bob Parks.
Old 11-11-2020, 10:08 PM   #9
pjmoreland
pjmoreland's Avatar
Will do. Thank you. I did see a comment he made on another thread about a weak magnet in the speedo.
Old 11-12-2020, 11:09 AM   #10
geezer#99
geezer#99's Avatar
What did you lube the cable with?
Did you pull it apart and clean it inside plus the cable.
geezer#99 is online now   Reply With Quote
Old 11-12-2020, 11:18 AM   #11
pjmoreland
pjmoreland's Avatar
I used a Teflon based light grease that is designed for bicycle cables. I pulled the cable out of the housing, wiped it off, applied the grease and reinstalled. I didn't clean the housing.
Old 11-12-2020, 11:44 AM   #12
geezer#99
geezer#99's Avatar
I clean them out inside and the cable with acetone.
Then use white lithium grease for lube applied sparingly.
Make sure the cable is held in place along the lower firewall too.
Old 11-12-2020, 11:46 AM   #13
pjmoreland
pjmoreland's Avatar
I'll give it a good cleaning with solvent. I have it fastened to the firewall with the original clip.
Old 11-12-2020, 12:33 PM   #14
Willys_MB
Willys_MB's Avatar
Sheesh, mine always wanders like that and I never really thought anything of it. I guess I have another thing to fix.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 11-12-2020, 01:22 PM   #15
pjmoreland
pjmoreland's Avatar
That's what I'm wondering. Maybe this is common simply due to the age of our trucks. This is my fourth C10, and none of my previous trucks had this issue, but the last one I had was 13 years ago.
Old 11-12-2020, 04:13 PM   #16
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have used graphite dust to lube the speedo cable, but the most reliable ground speed indicator is a GPS device on the dash.
Old 11-12-2020, 04:55 PM   #17
Davidf
I think cable issue is the most likely cause of a bouncing speedometer. I would remove the cable, pull the inner cable out of the sheath and a suitable lubricant (i.e. not lithium grease) such as:
https://www.amazon.com/Ags-Kable-Eas.../dp/B000ZO0EA2
Davidf is offline   Reply With Quote
Old 11-12-2020, 05:06 PM   #18
Willys_MB
Willys_MB's Avatar
I just put this new cable in and lubed the heck out of it, as did the OP, so I don't think it's the issue here
Old 11-12-2020, 06:19 PM   #19
Davidf
How the routing, do you have a sharp bend in the cable. Maybe disassemble the speedometer and lube the part of the cup/magnet part that the cable spins. Maybe it is binding due to hard grease at the housing.
Old 11-12-2020, 06:42 PM   #20
pjmoreland
pjmoreland's Avatar
The routing seems good to me, and there are no sharp bends. I already put a drop of light oil on the speedometer input shaft.
Old 11-12-2020, 07:19 PM   #21
Astro-Balls
Astro-Balls's Avatar
When I pulled my cable and housing out, Cleaned the inside of the housing and could not believe the grit and gunk that came out of it.
after a couple of good cleanings to the housing and cable, lubed with speedometer cable lube and good as new.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 11-12-2020, 09:45 PM   #22
'68OrangeSunshine
I have found those offset spedometer correction boxes [used when you have bigger than stock tires] tend to amplify the bounce.
Old 11-27-2020, 03:16 PM   #23
pjmoreland
pjmoreland's Avatar
I sent my speedometer to TBONE1964 and he ended up replacing the entire speedometer head with good used unit. The speedometer is drastically improved over my old unit. It is rock steady most of the time. It still swings around if I hit a bump or dip, but that seems unavoidable. Here's a video of it in action.
https://youtu.be/Cvvz8rQTz_E
Old 11-27-2020, 03:47 PM   #24
'68OrangeSunshine
My rig just rolled over 400,000.
Old 11-27-2020, 04:23 PM   #25
pjmoreland
pjmoreland's Avatar
Nice! That would explain your signature. I have no idea what the mileage is on mine. Probably less than that.
Thread Tools
Display Modes
