decent manual or electrical 4 way heater bypass valve?
About to embark on the adventure of replacing a leaking heater core on my '86 K5, and thinking this is a good time to also had a heater bypass valve, but I can't use the common shutoff valve that is being used in all the threads I've seen so far while searching.
Reason being that I have a big block that I built and swapped in, deleted the factory bypass hose from water pump to intake manifold, and am now using the heater core circuit + bleed holes in the thermostat for that purpose. Thus I'll need a valve that will continue to circulate coolant when in bypass. Sure, I could just choose one at random from the auto parts store, Amazon, eBay, etc...but I'd rather not gamble an expensive new engine on random choices, lol. So curious if there are any recommendations for this? |
Just here to tinker
![]() Join Date: Jun 2008
Re: decent manual or electrical 4 way heater bypass valve?
Why not put the factory bypass back in and not worry about it?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Just here to tinker
I use these in the marine industry a lot with heating systems. I'm sure this could work for you.
https://www.groco.net/products/valve...ree-way-valves
Thread Tools | |
Display Modes | |
