12-10-2020, 02:27 PM | #1 |
GM Crate motor
Anyone have any experience or comments on pt#19355658 GM crate engine? Its the 290 horse 4 bolt variety.
Smitty '71 Short Fleetside Spring Valley, Ca. |
12-10-2020, 04:53 PM | #2 |
Re: GM Crate motor
Smog heads, 8:1 compression, 1960s era cam that was used in a higher compression SBC which yielded good results... when Hendrix was still alive.
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-10-2020, 04:55 PM | #3 |
Re: GM Crate motor
Also, if you have a few hours, do a search on the engine. It's been covered pretty well.
12-12-2020, 12:12 PM | #4 |
Re: GM Crate motor
12-12-2020, 01:18 PM | #5 |
Re: GM Crate motor
It fits the era of out trucks. My son in law has one in his K10 and loves it.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
12-12-2020, 05:24 PM | #6 |
Re: GM Crate motor
Are you looking for an assembled long block to drop in, or would you be open to some assembly? With some work you can build your own, while taking advantage of sales and free shipping.
Just my 2c, I'd prefer to build a roller cam over a flat tappet as long as the added costs are within reason. If I had to do it again now, I'd probably buy a ZZ4 short block and add a roller cam/lifters & aluminum heads. The SP/ZZ block 12670966 has the GM roller cam retainer (no cam button needed) and supports a mechanical fuel pump. If you want to stick with the 350/290 long block, for about $1000 + head bolts and gaskets you could swap out the 76cc iron heads for 62cc, 65cc, or 70cc aluminum heads to bump up the compression and save some weight.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
12-12-2020, 06:06 PM | #7 |
Re: GM Crate motor
Looking for a replacement for the .060 over 350 with about 60,000 mi. On it. It’s developing a coolant leak through a porous head. Don’t require speed. Getting to old for that. But would like something that will get out of it’s own way. Looking for a long block so that I won’t be buying into the shop doing the swap for me. I’m in my early 70’s and the desire is to hit local car shows when the current situation improves. Am not as limber as I once was. I’m running a newly rebuilt 700R4, with the above mentioned 350. So I’m thankful for any opinions and suggestions. Because this is the greatest place to get this information. Thank you one and all.
Smitty
12-12-2020, 06:26 PM | #8 |
Re: GM Crate motor
What about a Vortec 330 hp crate engine? Better torque, milder cam and more HP. You will need a vortec intake.
Otherwise, I would go with the base 350 crate, add a 256 voodoo cam and reuse the lifters, timing chain and rockers.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
12-12-2020, 11:58 PM | #9 |
Re: GM Crate motor
That's a great option posted by Wesmigletz, and one of the options I considered.
Chevy Performance has the L31 crate on sale now for $3095 direct. Add an intake, an externally balanced flexplate, bronze tip fuel pump rod, and a (new) GM HEI w/melonized drive gear and you're good to go. https://www.gmperformancemotor.com/parts/12691673.html Machined and assembled in the USA. New 4-bolt main block. Forged crank. Hydraulic roller cam. 9.4:1. Mech fuel pump. No core charge, free shipping, etc. Not sure, but the stock cam may not have the lobe for the fuel pump.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 12-13-2020 at 12:09 AM. |
12-13-2020, 08:07 PM | #10 |
Re: GM Crate motor
Why not go with a 383 short block with Edelbrock heads and intake kit?
12-21-2020, 10:33 AM | #11 |
Re: GM Crate motor
It's a decent engine with just enough power to be fun.
In all honesty, get the 260hp version and install a reproduction 327/350hp cam to get better power results than the 290hp cam.
12-21-2020, 10:43 AM | #12 | |
Re: GM Crate motor
12-21-2020, 03:10 PM | #13 | |
Re: GM Crate motor
We have one in a Blazer and it requires a few things to be changed. The exhaust angle is different, and the rear bracket on the AC won't work.
12-21-2020, 03:29 PM | #14 | |
Re: GM Crate motor
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-21-2020, 06:29 PM | #15 |
Re: GM Crate motor
Pretty much have settled on the 350 HO. Only thing needed is fuel pump and starter.
12-21-2020, 06:32 PM | #16 |
Re: GM Crate motor
This one! Local dealer matched the price.
https://www.gmperformancemotor.com/parts/19210008.html I do appreciate the input and opinions everyone submitted for me to consider.
Smitty '71 Short Fleetside Spring Valley, Ca. Last edited by Smitty; 12-21-2020 at 06:44 PM. Reason: Addition |
12-23-2020, 09:47 AM | #17 |
Re: GM Crate motor
This engine is pretty amazing, to be honest. My dad had one in his 87 Monte Carlo.
12-23-2020, 10:16 AM | #18 |
Re: GM Crate motor
My Brother who got me the deal at the dealership has one in his ‘71 and loves it. He was influential in my decision. So mid Jan. Am going to make it happen.
Smitty '71 Short Fleetside Spring Valley, Ca. Last edited by Smitty; 12-23-2020 at 10:17 AM. Reason: Spelling |
12-23-2020, 03:13 PM | #19 |
Re: GM Crate motor
Excellent Smitty, should give you nice little boost!
1971 Custom/10 - 350/3 speed, Orange/White roof |
Thread Tools | |
Display Modes | |
