12-31-2020, 03:44 PM | #1 |
Looking For a Picture of a Truck with Factory Clutch and a Brake Booster
My 1970 C10 has a 3 OTT and I just added a factory brake booster and disc/drum master cylinder which is causing the brake pedal to sit several inches lower than the clutch pedal. I have another thread going trying to find the correct way to solve this issue and have received a few answers. Some people have said that the brake pedal on a truck with a brake booster normally sits lower than the clutch pedal.
In this thread I am trying to find someone with a photo of a truck that came factory with a manual transmission and a brake booster, to see if the pedals actually sat even with each other or if they were offset with the brake pedal being lower. |
12-31-2020, 04:37 PM | #2 |
Re: Looking For a Picture of a Truck with Factory Clutch and a Brake Booster
72 C10 3OTT - I did add booster though.. I THINK I took it out of a 72....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
12-31-2020, 04:51 PM | #3 |
The brake pedal will move down when the truck is running and the booster is active, FYI
1968 GMC C2500 Long Bed Fleetside |
12-31-2020, 04:59 PM | #4 |
Hey luvlegs, thanks for the pics. How much lower would you say that the brake pedal is from the clutch?
12-31-2020, 06:34 PM | #5 |
Old member
Here is my pedals. Clutch is 7" off the floor and the brake is 5-3/4".
12-31-2020, 06:41 PM | #6 |
Thanks for the pics and measurements Andy. Did your truck come from the factory with a booster or did you add it?
12-31-2020, 06:50 PM | #7 |
Mines the same as Andy's
12-31-2020, 07:00 PM | #8 |
Old member
I added the booster. I just had a whole 86 front disc brake system installed back this summer. Master cylinder, all the way down to the pads.
Thread Tools | |
Display Modes | |
