03-04-2021, 01:11 PM | #1 |
1972 AC/Heater Control Lever Change Out
Has anyone replaced a broken lever on their AC/Heater control? I see the truck shop sells 3 levers for about $16. How easy/difficult is it? It looks like there are 2 pins that hold the stack together.
It looks like the 2 outside pins are peened that holds the levers in place. Does anyone sell these pins? Any help is appreciated. Last edited by jlampka; 03-05-2021 at 09:49 PM. |
03-04-2021, 03:24 PM | #2 |
Re: 1972 AC/Heater Control Lever Change Out
The most difficult part is removing the head from the dash. If I recall correctly you can just turtle up under there and pop off the levers from the cable ends and pull them out, then replace them. Good light n patience come in handy. Tag in n correct me if not guys....
03-04-2021, 04:04 PM | #3 |
Replacing the levers is easy once you have the panel out. To take the panel out of the dash it should just be two screws through the bottom of the dash into the panel. Disconnecting the cables can be a pain though.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-04-2021, 07:17 PM | #4 |
The Older Generation
I posted this thread on removing the retainer clips from the cable ends. http://67-72chevytrucks.com/vboard/s...d.php?t=211815 LockDoc
11-02-2021, 10:14 PM | #5 |
Glad I found this thread as I now know where I can get new heater control arms. I got the assembly apart but to do it I had to drill off the swaged end that hold the lever stack together. My question is when I go to reassemble it what did you use to keep the end support on?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
11-02-2021, 10:30 PM | #6 | |
Go to the hardware store and take the pin with you. See if they have a longer pin and the same style of clips that hold the cables to the levers but the correct size for the pin. LockDoc
11-02-2021, 11:17 PM | #7 | |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-04-2021, 08:30 AM | #8 |
Thanks trickster. Wasn't sure if I should try and drill and pin the posts or tap them and use a screw. The ac lever must be the weak link. I have two control assemblies and the same arm is broke on both. I thought about using epoxy to glue it back together. Then reinforce it with some small steel straps.
I am converting over to the Vintage air electronic controller. Since you cut off the one tab on the center arm it should not snap again.
11-04-2021, 12:26 PM | #9 | |
11-04-2021, 07:48 PM | #10 |
Try lubing the cables, the original levers are pot metal and cannot take too much force before breaking. One of the parts vendors (maybe several) sell steel levers.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-04-2021, 10:49 PM | #11 |
There's a youtube video from Brothers that shows a rebuild of the heater controls. It's worth the time to watch.
If controls aren't working smooth cables are usually a big part of the problem, they get old and seize up.
I got a bench seat baby, you don't have to sit over there. |
Thread Tools | |
Display Modes | |
