Old 03-05-2021, 01:29 PM   #1
forestb
forestb's Avatar
rear lug bolt remuval
I am trying to get one of the lug bolts out of my rear axle while it is still installed. Does anyone have any tricks, other than hitting it with a big hammer?
I'm thinking maybe some heat or soaking it in liquid wrench. Not at the same time of course.
forestb is offline   Reply With Quote
Old 03-05-2021, 01:38 PM   #2
val1gonzales
Re: rear lug bolt remuval
I've always just sprayed the base of it with some WD-40 and hammered it right out. They don't usually give you any issue. Then using the nut draw it back in.
val1gonzales is offline   Reply With Quote
Old 03-05-2021, 01:56 PM   #3
forestb
forestb's Avatar
I have tried hitting them with a hammer. It almost looks like the PO might have tack welded them in from the back or something.
Old 03-05-2021, 02:05 PM   #4
val1gonzales
Ouch! If its welded you might have to try and drill it out. May be best to take the axle out and see what's going on there and easier to work on it as well. Maybe grind both front and back side then try to punch out middle piece. All time and money consuming but that's what this resto-love entails.
Old 03-06-2021, 11:36 AM   #5
bsarts
bsarts's Avatar
If it is indeed welded on in the back, then it is probably because the hole is wallowed out and the knurling on the stud will not hold it tight in the flange. You would have to weld your new one in or get another axle. Or take it to a machine shop....
bsarts is offline   Reply With Quote
Old 03-06-2021, 11:55 AM   #6
forestb
forestb's Avatar
I hope none of that is true
Old 03-06-2021, 06:13 PM   #7
jayoldschool
Moderator
I always pop them out with a 3lb sledge, then pull in new with upside down lug nut and a socket spacer. For flange with wallowed knurl, you can get lugs with larger seat diameters. I used an M12x1.5 from a Hyundai on my Impala SS after cross checking the charts.
jayoldschool is offline   Reply With Quote
Thread Tools
Display Modes
