Old 12-22-2003, 08:31 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Skokie......... let it breathe!
Here's a couple of ways to set up your breather.
In the picture below:
-collar for under air cleaner
-aftermarket air cleaner base with fitting
-valve cover push in fitting
Old 12-22-2003, 08:37 PM   #2
Tx Firefighter
Here it is in place. The collar fits on top of the carb, under the air cleaner.
The yellow deal is a rubber hose.
You should be able to get the collar and valve cover fitting from someone on the part's board.
You can also connect the hose the the bottom of an aftermarket air filter that has a fitting on it.
There are other ways, but this is stock and this is how I like to do mine.
Old 12-22-2003, 08:45 PM   #3
skokie
skokie's Avatar
Tx. Once again thanks. BTW is that hose goingto be 3/8?
skokie is offline   Reply With Quote
Old 12-22-2003, 08:46 PM   #4
Tx Firefighter
closer to 3/4"
Old 12-22-2003, 08:51 PM   #5
skokie
skokie's Avatar
OK. Couldnt tell from the pic.
Time to hit the parts board.
Thanks again Tx Firefighter.
Thread Tools
Display Modes
