Old 06-06-2021, 05:18 AM   #1
OregonNed
OregonNed's Avatar
Gear ratio advice
My truck is currently getting its rear differential rebuilt (a lot of problems found internally). It currently has open carrier with 3.08 gearing, but here is my chance to change the ratio for a bit more umph! We are switching to Posi as well. I’m running 27in diameter tires, and I’ve studied the RPM charts. Now thinking about 3.42 or 3.55 for it. Any opinions on one vs the other? Running a 327 with TH350 trans as well. Thanks in advance
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-06-2021, 08:43 AM   #2
Accelo
Accelo's Avatar
Re: Gear ratio advice
I think you will be running right in the sweet spot with 3.42 or 3.55 gears.
Stock camshaft? If so you might consider the 3:42 ratio. With a mild camshaft do the 3:55 and don't look back.
Rick
Accelo is offline   Reply With Quote
Old 06-06-2021, 10:31 AM   #3
OregonNed
OregonNed's Avatar
Thanks for the reply. My cam is not stock and I have been leaning towards 3.55
Old 06-06-2021, 11:59 AM   #4
pjmoreland
pjmoreland's Avatar
I have 3.73 gearing. With a TH400 trans, my truck was a bit intense on the freeway at speeds over 60 MPH. I had. '67 years ago that had 3.07 gearing. It was great on the freeway, but it was a dog around town. Going somewhere in the middle makes a lot of sense. Personally, I would be inclined to lean more toward a ratio that is better for freeway driving, but it really depends on how you plan on using your truck. If you have a relatively quiet exhaust system, then that will make higher numeric gearing more tolerable at higher speeds.
pjmoreland is offline   Reply With Quote
Old 06-06-2021, 12:52 PM   #5
jimijam00
Cam specs?
What is your ratio of freeway/highway to city driving?
jimijam00 is offline   Reply With Quote
Old 06-06-2021, 03:56 PM   #6
OregonNed
OregonNed's Avatar
It’s a mild cam. Have no idea of what went in when the PO rebuilt the engine. Gonna guess city/freeway is going to be about 50/50
Old 06-06-2021, 07:28 PM   #7
roboticjunky
If you have a truck 12 bolt rearend, then go with 3.42 gears since they don't make 3.55 gears for the truck 12 bolt rearend.
They do make 3.55 for car 12 bolt rearends.
roboticjunky is offline   Reply With Quote
Old 06-06-2021, 07:42 PM   #8
OregonNed
OregonNed's Avatar
Thank you good to know that. Appreciate the help
Old 06-07-2021, 09:06 AM   #9
tim_mc
tim_mc's Avatar
I'm also planning to have a spare 12 bolt rebuilt as a posi this year. I really like my 3.08s but also have a 700R4 with lower 1st and 2nd gears than the TH350. I love running 75+ at 2000 RPM, but most of my driving is local. I go back and forth on 3.08 or 3.42, but currently leaning toward 3.42 as I don't think I'd give up too much with 4th + lockup. If I still had the TH350 I'd almost certainly go with 3.42 gears.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 06-07-2021, 02:00 PM   #10
schovil69
The difference between 3:42 and 3:55 is not likely to be noticeable, darn near identical. Throw a dart at a paper with the two ratios written on it and choose the one that the dart is closest to.
schovil69 is offline   Reply With Quote
Old 06-07-2021, 03:15 PM   #11
Wrenchbender Ret
If you have been running a 3.08 & go anything lower you are going to be disapointed the first time you get out on the highway. You will be waiting for the thing to shift again.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-07-2021, 03:18 PM   #12
jimijam00
Originally Posted by tim_mc View Post
i love running 75+ at 2000 rpm, but most of my driving is local.
3.73.
Thread Tools
Display Modes
