Old 07-14-2021, 06:28 AM   #1
toymanbob
Hated to add something shiny
I may have to paint it brown. Naw but am closer to my first drive.
http://67-72chevytrucks.com/vboard/s...d.php?t=820010
toymanbob is offline   Reply With Quote
Old 07-14-2021, 02:00 PM   #2
mr48chev
mr48chev's Avatar
Re: Hated to add something shiny
I don't know how well those take t being painted radiator black
My ongoing truck projects:
Old 07-19-2021, 03:05 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
That's a nice unit. Make your first drive down to the ice cream shop on 7th St. Friday evening.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-21-2021, 08:52 AM   #4
toymanbob
I'm ready for my first drive but......I can't find any used 15" tires!!!! My local tire guy had none. Not one 15"!! Who knew that this would stop me. I will widen my search today and hope for success.
Old 07-21-2021, 06:53 PM   #5
toymanbob
Score! After stops at four tire shops and turning up empty it was suggested that I check the local metal recycler as they had used tires. What? Why? They recycle cars for the steel and sell good used tires on the side. I got four mounted and balanced for $140. Yeah! Les Schwab wanted $189 for one new one. The tire shops state that by the time people buy new tires to replace their 15" tires they are well worn and can't be resold.
Old 07-23-2021, 07:22 PM   #6
toymanbob
Sitting on it's own tires and wheels for the first time! I like the stance, the wheels look perfect, it is full of fluid and ready for the first test drive but.......................When I tried to shift out of park today, there was no connection to the shift rod. I knew it could happen when I took the el cheaper path to obtaining a short steering column. These steering columns, made by Saginaw and shared by GM and Chrysler, can be shortened easily by just applying enough force to collapse the column to the desired length. The problem is internal, the shift connection between the shift lever and the tab that connects to the trans is two tubes that are locked together by nylon tabs that break when shortened. Tomorrow I'll pull the column, try to locate the hidden connection point, cut a slot and mig weld the two tubes together. Anyway, here it is
Thread Tools
Display Modes
