01-09-2022, 11:08 PM | #1 |
Dakota Digital American Autowire
Which Wires Do I Need And Which Should I Cut out Of The Way?
Trucks a 69 c10 I Noticed a Gray Dash Light Wire… Needed? Thanks Posted via Mobile Device |
01-10-2022, 02:55 AM | #2 |
Re: Dakota Digital American Autowire
Description is A little vague? Can you elaborate?
One gray wire, I can think of, is the one that powers the tilt column light. Others are the heater controls illumination. Cheers. |
01-10-2022, 10:03 AM | #3 |
I just installed the AAW harness and Dakota Digital gauges. If I understand your question, I did not use the Temp or Oil Pressure wires on the harness as the gauges had their own. Pretty sure I used everything else though. It was just a matter of running the wires to the control box instead of pinning them out to the factory gauge plug.
01-19-2022, 01:50 PM | #4 | |
Just Wondering What You Did For Constant Power And Accessory Power? Not Sure What The Dim Is For As Well If I Need The Tan Brake Wire? Thank You Posted via Mobile Device |
Thread Tools | |
Display Modes | |
