01-15-2022, 03:23 AM | #1 |
Sound deadener between door and door panel 67-71
I almost forgot about the Sound deadener between door and door panel.
I didn't plan for it and wanted to get my panels installed. I had a left over roll of the foam insulation for ducting purchased from Home Depot. I decided to give it a try as backing. Cut it to fit between the foam tap and the top of the door. Just cut it with scissors. Panel went on nicely without issues. I think I have a winner? Cheers. |
01-15-2022, 04:06 AM | #2 |
Re: Sound deadener between door and door panel 67-71
Should work well. I would recommend sealing up that hole at the back of the door on the top, at least with tape. Have found most of the noise comes from the air leaks.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-15-2022, 04:13 AM | #3 |
Duct tape to the rescue! LOL.
I have a set of the air dams that go in the hinge area. Are they worth installing? thanks |
01-15-2022, 04:23 AM | #4 |
IDK? Have them myself but am missing the brackets to install as my truck is not a Cheyenne. Require staples and extra holes. Even if I can source the brackets it is not a priority for me.
01-15-2022, 05:04 AM | #5 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Every little bit helps!
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
01-15-2022, 08:21 AM | #6 |
Mr. Cheyenne
I have those air dams to fix up and to install. It appears mine are missing, my guess ~12 years ago the person/persons working on the truck decided not to reinstall them.
Though after getting the air dams and the parts to refurb them, which that in itself seems like a pain, I decided to push doing anything with them to the very bottom of my list. Best that I can tell you got to remove your fenders to get them on (and whatever else needs to come off to get fenders off). I guess you haven't put you fender back on yet Accelo? When you go about installing them, I'd love to see real good / multiple angled photos. Heck I'd love to see a dedicated thread on the install of them.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
01-15-2022, 08:33 AM | #7 | |
Mr. Cheyenne
But like I said in my post before, they totally went to the bottom of my list - they are likely stuck there as I put my box of parts into my attic!
01-15-2022, 10:45 AM | #8 |
Post Whore
Looks good, just be aware of the drain holes so water doesn't get trapped.
Here is a link to what I found with mine. https://67-72chevytrucks.com/vboard/...d.php?t=798102
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-15-2022, 12:32 PM | #9 |
You mean the ones at the bottom of the door? Or am I missing something? I also taped up the gap I left on the drivers side. I hadn't cut the passenger side, before I posted, so I left an ea,r on it, to cover the gap. I also had to removed 1/2" of material from the very top so the panel would clip in. That was completed after the picture was taken. |
01-15-2022, 01:11 PM | #10 | |
Post Whore
Those rubber beads just below the oval holes need to be watertight to the door and the door panel to keep water from running out from under the door panel.
01-15-2022, 08:46 PM | #11 |
^^Wow, not that I'm the expert but I never knew about those holes, thank you!
01-15-2022, 10:04 PM | #12 |
That's not sound deadener, it's just insulation. It will not dampen panel vibrations.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-16-2022, 03:28 AM | #13 |
Why I recommended sealing up the leak. Typically, I applied sound deadender in strips on outer door skin. Companys like Dynamat and Accumat love that people cover entire panels and openings with their product. It is not necessary, but people still do it.
01-16-2022, 03:38 AM | #14 | |
01-16-2022, 11:34 AM | #15 | |
Just FYI, here are my favorites for sound deadening and insulation: For sound deadening, this stuff has slightly thinner butyl rubber, but works well and is SIGNIFICANTLY less expensive than the name brands: https://amazon.com/gp/product/B01BKK...ch_asin_image? - - - - For insulation, the product below made by Bonded Logic is available with foil on one side or both sides, with cotton from recycled blue jeans in the middle. https://www.speedwaymotors.com/Alumi...ded,32193.html
01-16-2022, 11:48 AM | #16 |
I learned a lot on this thread. Completely missed the drain holes in the door. Wondering how this changed in 1972? Any pictures of the 72 door we can add? I was interested in replacing vapor barrier with something on hand. With some luck my truck will never see any rain again! Vibration is another/separate issue. I do appreciated the links. My thought is most of the products are overpriced to pay for their marketing.
Anyone else notice the difference in the shape of the hole in the door? The one Richard pointed out was uncovered. One is round and the other (1970 door hole) pear shaped. If your serious about quieting down your truck add a overdrive transmission. Eliminating the source is a better policy than attempting to block the noise. Last edited by Accelo; 01-16-2022 at 11:58 AM. |
01-16-2022, 12:23 PM | #17 | |
When I added sound deadening material to an 1982 C10, it made a tremendous difference -- from the sound of closing doors to road noise. I mean the improvement was noticeable as soon as I backed out of the driveway and drove down the street. Same was true of a 55 Chevy car, which the first time I used sound deadener.
01-16-2022, 12:29 PM | #18 |
Guess my headers would also need to go! LOL.
And my Black Widow "ANGRY HOUSEWIFE'S mufflers. Last edited by Accelo; 01-16-2022 at 12:41 PM. |
01-16-2022, 12:39 PM | #19 |
Long tube headers can be big-time source of heat to the floors. Same is true of 2.5" pipes tucked up high. Ask me how I know!
I guess there are some downsides to using this, but wrapping pipes helps a lot. https://www.summitracing.com/parts/dei-010123
01-16-2022, 05:42 PM | #20 |
Active Member
I think your sound barrier is a great idea, its also a dampness barrier that will keep door panel from getting rusty, as well as help with radiant heat entering the cab from the door skin.
01-17-2022, 06:52 PM | #21 | |
Post Whore
I would bet the round holes were a mistake during the design of the new 67 model and at some point GM modified the inner door skin holes to speed up the assembly process. Possibly the round holes were a carry over from the 66 model year.
01-17-2022, 09:52 PM | #22 | |
01-18-2022, 01:31 AM | #23 |
I thought this was an interesting water/rust pattern on the back side of my used door panel. My guess is it is indicative of the water path inside the door.
I should have used different nomenclature in the title. Possible vapor barrier would have avoided some confusion. Never the less, this was an interesting thread. I learned a lot from it. |
01-18-2022, 09:36 AM | #24 |
Post Whore
That's interesting! Now I know I have 67 doors on my 67 Burban. The doors have 68 and up wing windows and door handles. I have wondered if the doors had been swapped.
Thread Tools | |
Display Modes | |
