12-31-2003, 02:53 PM | #1 |
PROJECT 7DEUCE
L.e.d problem's??
I installed l.e.d bulb's a day or so ago and replaced the flasher with an electic one.. The problem is when the headliught's are on the turn signal's don't work but everything else does??? Do I need to replace the big flasher on the top of the fuse box with an electric one also??? Any help would be great ....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-31-2003, 07:09 PM | #2 |
Weapons Of Construction
Hey French!
Sounds like you have a ground problem with your bed that somehow got amplified with the LEDs since they draw less current. Check your grounds at the lamp sockets and between the bed and frame, and between the engine and chassis. As far as the flasher on the fuse panel, it shouldn't matter unless you use the hazards.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
12-31-2003, 07:35 PM | #3 |
PROJECT 7DEUCE
I guess I will go check the ground's it does seem enterminit...
Thread Tools | |
Display Modes | |
