05-05-2022, 03:27 AM | #1 |
R.I.P. E.S.L.L.
Door window visors
I had some on my 70 GMC. I really liked them I want to get some for my 70 and 71.
My question is, how do you put these things in? I've looked and found nothing. But then again I'm ignorant. Ignore the hag in the photo. I want the visors again, not her.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
05-05-2022, 06:59 AM | #2 |
Re: Door window visors
There are 4 clips that fit in the upper window channel, So you pull the window channel gasket loose starting at the top/front and back to where the channel falls down the back side of the window . Install the 4 clips spaced evenly and the shade slides up and under the edge of the door and under the clips , Go slowly it's real easy to scratch the paint .Once you have the shade installed .Reinstall the the gasket and your good to go . it might be easier to install the shade and then the 4 clips it's been a wile since I used them . They used to sell the same style shades that installed with 4 small screws and those were a real PITA to install .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-05-2022, 07:22 PM | #3 |
Here's an old thread of mine with photos of the clips. No installation pictures, but it was easy as explained in this thread...
https://67-72chevytrucks.com/vboard/...d.php?t=800716
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
05-06-2022, 09:16 AM | #4 | |
R.I.P. E.S.L.L.
05-06-2022, 09:18 AM | #5 |
They first used to come with small screws and you drilled the door on the edge. It was easy to mess up your door. I drilled and screwed some (I run them on all my trucks). At some point I began just sticking them in. That's how they are on my '72 GMC. Every now and then I'll have to push the back corner up when I notice it dropped some. They won't blow out. And my truck still has original window channel. I imagine just a dot of adhesive would keep them from dropping
05-06-2022, 09:37 AM | #6 |
The shades were nowhere near the hardest part of my build. Of course, the doors were completely disassembled for refurb when I installed mine. Still...removing the seals and installing shades with clips should be easy unless your seals have been glued in.
Thread Tools | |
Display Modes | |
