05-29-2022, 08:49 AM | #1 |
3.5" BS 18x9 will they fit?
I found a set of Dtowns in 18x9 with 3.5" BS and would like opinions on if they would work on a 63 long fleet 5/7 static drop. From what I found in need a 4.5" BS or 0 offset am I correct in my research.
63 C10 SBW Long Bed 67 Chevelle SS396 15 HD RGS |
05-29-2022, 11:49 AM | #2 |
Re: 3.5" BS 18x9 will they fit?
Curious as well...
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
05-30-2022, 09:32 AM | #3 |
Depends on how the drop was done.... That being said, I'll wager it would be too close to the edge of the fenders.
06-01-2022, 02:36 PM | #4 |
I have 8" with 3 3/8" BS and 235 wide tires, the sidewall is about 1/2" from the wheel opening lip. '66 Fleetside, stock rear axle. You'd need the extra width on the inside, or more backspacing to get 9" to fit.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Thread Tools | |
Display Modes | |
