Old 01-02-2004, 03:08 AM   #1
dropped_71chevy
overheating problems
My truck got hotter than usual (not really overheated just above 180 degrees, which is normal) about a week ago and I decided that my heater core was the culprit.
I replaced the heater core and was on my way. Two days ago it overheats again. I fill it with about a gallon of 50/50 mix. Today it overheats again. I fill it and it goes back to normal of course.
What would cause this to happen? I pulled the dipstick and tried to smell and see if there was any antifreeze in the oil. I couldn't tell. Tomorrow I will do a sniff test with some plain oil and some of my engine oil to see if there is a difference. The only thing about that is that my oil level hasn't gone up at all.
When it overheats there are two little puddles on either side of my intake manifold where it meets with the head.
Also, my oil pressure is high when it's cold and then when it is at operating temperature it drops down to exactly half on the stock gauge. It goes up as I accelerate.
Would my exhaust smell funny if I was burning antifreeze?
I recently built this engine. We dyno'd it and it held together fine for about 3 weeks until it got hot that first time.
Any help is greatly appreciated. Sorry about the long post.
dropped_71chevy is offline   Reply With Quote
Old 01-02-2004, 03:13 AM   #2
Hooter
My other Love
Hooter's Avatar
is your thermostat sticking? how bout the water pump?
radiator flowing nicely?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-02-2004, 03:19 AM   #3
dropped_71chevy
I don't think its the t stat cause I'm losing a gallon of antifreeze every two days almost, new water pump-no signs of it going bad,
How do I check the radiator flow?
Old 01-02-2004, 03:27 AM   #4
Hooter
My other Love
Hooter's Avatar
give your rad hose a squeeze and you should feel it surge when you let it go, while it is running
pictures of my life
Old 01-02-2004, 03:30 AM   #5
dropped_71chevy
ok, thanks
Old 01-02-2004, 03:34 AM   #6
dropped_71chevy
What is the chance that I could have that much coolant in my oil or that I can burn that much coolant
Could my head just need to be retorqued?
Old 01-02-2004, 03:45 AM   #7
Hooter
My other Love
Hooter's Avatar
if you were burning antifreeze youd notice a lot of white smoke out of the tail pipes and your oil would be really milky
pictures of my life
Old 01-02-2004, 04:15 AM   #8
dropped_71chevy
ok I think i'm clear there, my oil still looks like oil and i'm not blowing any smoke
I think i'm gonna pull a quart and see what it looks like first before I totally blow off that idea
Thanks for all the help Hooter
Old 01-02-2004, 04:29 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Have you ruled out a leak from your thermostat housing?
You say there is coolant on your intake, the rest of it may be rollong off the back of the intake when you take off.
Old 01-04-2004, 05:47 PM   #10
dropped_71chevy
I wiped off all the coolant off my intake and then started it up again then it pooled on the rear of the passenger side of the intake. I tightened down my intake and haven't had any problems
Old 01-04-2004, 07:15 PM   #11
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
an intake needs to be properly TORQUED down make sure ya check your haynes/chilton manual and set it right in the proper order and ft pounds
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-04-2004, 09:53 PM   #12
dropped_71chevy
it's an edelbrock performer intake 25 ft/lbs of torque to tighten, some of the bolts are impossible to get to with a torque wrench so you have to play it by the seat of your pants.
Old 01-04-2004, 09:54 PM   #13
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I'd like to know how you get YOUR torque wrench on some of those bolts.
Cat Fuzz is offline   Reply With Quote
Old 01-04-2004, 11:02 PM   #14
cableguy0
sbc chevy intakes are torqued by feel theres no way to accurately torque down all the bolts its pointless just go in sequence and dont crank down hard on em
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-04-2004, 11:03 PM   #15
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
just get a u-joint and an extension
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 01-04-2004, 11:29 PM   #16
Longhorn Man
In reality, that would lead to inacurate torque readings.
Old 01-05-2004, 04:46 AM   #17
dmec
dmec's Avatar
have you checked your radiator cap? maybe it is weak and alowing the coolant to go out the overflow tube when it expands.
dmec is offline   Reply With Quote
Old 01-05-2004, 08:16 AM   #18
Longhorn Man
Why check the cap?
Old 01-05-2004, 09:31 AM   #19
cwilli84
1FINE69
cwilli84's Avatar
Also check the water outlet right where it comes off the intake dome to the nipple area I had it cracked but near invisible to the eye. It was a cheap aluminum chromed job so I put a good cast piece on.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Thread Tools
Display Modes
