06-27-2022, 06:26 PM | #1 |
Radiator shopping
I'm looking for a radiator for my 66, soon to be powered by a 350 Vortec making around 380hp, with air and auto. I'll be using a clutch fan and will fab a good shroud to fit whatever rad I get. I want a good rad that'll cool for a budget price. A lifetime warranty is a must.
In reading old threads, it looks like wide tubes in the core are better than narrow, ie 2 x 1" is better than 3 x 5/8", so I've narrowed my choices to: Champion radiators.com 2-row 3/4" tubes $194.98 Speedcooling.com 2-row 1" tubes $297 Championcooling.com 2-row 1" tubes $269.95 I guess the headscratcher here is why are there two businesses with nearly identical names? Any feedback on these choices, or any other options in this price range? |
06-27-2022, 06:34 PM | #2 |
Moderator
Re: Radiator shopping
These ensure a cool running engine - Short water pump, Hayden 2947 Clutch fan, Hayden 6 blade 17 inch fan, Stock Fan shroud, proper seals around the radiator, hood to latch area seal.
I have a US Radiator Desert Cooler though with 2 rows 1-1/8" tubes. Radiator lower heat exchanger for the trans oil. But first it goes thru a 20,000 GVW Hayden Trans Cooler in front.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-27-2022 at 08:08 PM. |
06-27-2022, 07:43 PM | #3 |
Ive been running the Speedcooling radiator for 5 years or so now. No complaints. In fact it works well enough that I swapped my heavy duty fan clutch for a standard one and my 283 still doesn't overheat even with A/C in triple digit ambient temps.
06-27-2022, 08:09 PM | #4 |
I bought a 4-row from Champion Radiators for my '61.
Looks nice. No idea how good it's going to be. Or bad.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-27-2022, 08:33 PM | #5 |
Check out RnD fabrication
06-28-2022, 09:29 AM | #6 |
Rocknrod, thanks for the detail. The Hayden 2947 Clutch and Hayden 6 blade 17 inch fan look to be standard rotation, so I think the Hayden 2786 will work with my stock serpentine. I think I'll keep the stock fan if it's comparable to the 17" Hayden.
06-28-2022, 09:40 AM | #7 |
AcampoDave, how did you mount the Speedcooling radiator? Does it fit the stock saddles? What did you do for a shroud?
06-28-2022, 10:31 AM | #8 |
I've used several champion radiators and had good luck with them. I have one in my 62 and it works great and was a perfect fit.
06-28-2022, 10:50 AM | #9 |
62c30, which champion radiator site?
https://www.championradiators.com/ https://www.championcooling.com/ |
06-28-2022, 10:55 AM | #10 |
The one I ordered for my 62 I think was from their eBay store 4-5 years ago. I ordered one for my 61 from I think champion cooling. I had to call them for some reason and I do remember they had a record of me buying the one for my 62. Customer service was good, of course that was a year or two ago, hopefully still good.
06-28-2022, 06:38 PM | #11 |
https://speedcooling.com/product/196...inum_radiator/ this is the one that I have. It's designed to be a drop in replacement so your stock shroud still fits. The curious part is that when I went to put it in, my lower saddles were too narrow for the bottom tank and I had to split them apart and weld in a small extension. That was easy enough, but afterward I posted something about having to do that on this forum. Within a short time, I received a PM from the company rep asking for more details. I called him and he said those radiators are designed to be a direct replacement and the fact that I had to modify my saddles was concerning to him. He said that they were going to double check their design and figure out what the deal was. I never heard another word afterward so I can't say what happened.
06-28-2022, 08:22 PM | #12 |
AcampoDave, that's the Speedcooling I was looking at. My truck was a six, so the saddles are likely too narrow but I'll do 'em like you did.
06-28-2022, 09:30 PM | #13 | |
06-30-2022, 12:11 PM | #14 |
SkinnyG, the specs and prices are different.
06-30-2022, 06:58 PM | #15 |
And yet, they share the same logo in there.
And Champion Radiators boldly states on their web page that they carry Champion Cooling products. And Champion Radiator sent me a Champion Cooling radiator, packaged in a Champion Cooling box. Pretty sure they are the same product.
07-03-2022, 03:39 PM | #16 |
I have the American eagle radiator(made by champion but has wider tubes). Homemade shroud and SPAL fans. Been working great.
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
07-05-2022, 10:56 AM | #17 |
I use a Champion radiator with a Chevy HHR electric fan on it. The fan is cheap and comes with a shroud that fits the radiator really well. Keeps my 400 hp 427 cool. I had to fab some brackets to mount the fan.
07-05-2022, 03:22 PM | #18 |
Thanks blue! Can you tell me how many and what size tubes the radiator has? I'll check out the HHR Fan - I like cheap and effective.
07-05-2022, 03:26 PM | #19 |
Karlbenz, thanks for the reply. American was not on my list, but wider tubes are said to be better. Are you a tin bender? Would you share a photo of your shroud?
Thread Tools | |
Display Modes | |
