01-02-2004, 11:22 AM | #1 |
What does screw do on this carb?
I'm not a carb man......
What does this screw do? Thanks for any help! |
01-02-2004, 11:26 AM | #2 |
I would have to say it's the float adjustment
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
01-02-2004, 12:50 PM | #3 |
Weapons Of Construction
Fast Idle adjust?
It's a long way from the fuel inlet to be the float level adj.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
01-02-2004, 04:59 PM | #4 |
Thanks for the responses...
01-02-2004, 07:41 PM | #5 |
That is the idle vent valve. At idle or when the engine is shut off the vent releases fuel vapors. The vent maintains atmospheric pressure in the fuel bowl.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
Thread Tools | |
Display Modes | |
