Old 01-02-2004, 11:39 AM   #1
dubie
dubie's Avatar
oil PSI line
I have my 72 in the shop at work here and I am trying to figure out where the oil psi line goes. It screwed into the block on the inline 6 but where does it go on this 350? the engine is from and 82
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 01-02-2004, 11:41 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Behind the distibuter on all small blocks I've seen.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-02-2004, 12:03 PM   #3
dubie
dubie's Avatar
Ok, here is the problem
This is the oil psi line from the inline
Old 01-02-2004, 12:03 PM   #4
dubie
dubie's Avatar
and it's supposed to hook up to this??
Old 01-02-2004, 12:06 PM   #5
cdowns
cdowns's Avatar
looking at the block just in back of the intake manifold on the drivers side is where that oil line will screw into the block
Old 01-02-2004, 12:18 PM   #6
cdowns
cdowns's Avatar
pic
Old 01-02-2004, 12:21 PM   #7
dubie
dubie's Avatar
ok so all i have to do is unscrew the one in this pic and screw the factory line in.
MAny thanks
Old 01-02-2004, 12:23 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Good pic, that's it. If I were you I'd go to NAPA and get a replacement line for the V8. The I6 line is too long and may break or get kinked in your effort to route it.
Old 01-02-2004, 12:25 PM   #9
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Remove the pressure sending unit thing there behind the dist and put your line fitting in its place.
Beat me to it
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 01-02-2004, 12:30 PM   #10
dubie
dubie's Avatar
Thanks Jeff, that was my next question That line looked WAY to long and I was trying to figure out how to make that fit
Old 01-02-2004, 12:34 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
The replacement may be some sort of plastic line, or my was anyway. Works great and no fear of it getting distressed by vibration. Just keep it away from your exhaust manifolds
Old 01-02-2004, 12:38 PM   #12
dubie
dubie's Avatar
this is the one that threads into your gauge in the dash bezel right?
Old 01-02-2004, 12:47 PM   #13
CPNE
Resident Curmudgeon
CPNE's Avatar
It's been a while since I had that trucck with the replacement line, but I believe it ran directly from the block to the sending unit on the dash. The stock configuration used 2 separate steel lines coupled together outside the firewall. The stock line that attached to the block was coiled like a slinky to help with the vibration cracking problem, the other stock line it was coupled too was straight thru the firewall to the pressure gauge.
Old 01-02-2004, 01:43 PM   #14
bigvinnie
bigvinnie's Avatar
you could also probably get one free or dirt cheap from a V8 truck at a junkyard...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 01-02-2004, 01:46 PM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Junkyard parts - Dirt cheap.
Not freezing your a$$ off in Flin Flon Canada in January - priceless.
Old 01-02-2004, 01:51 PM   #16
dubie
dubie's Avatar
hahah yeah it's gonna be -42F for the next 2 days HOw bout you go out there and get one for me
Old 01-02-2004, 02:01 PM   #17
gonebad2
Merciless Butcher
gonebad2's Avatar
Go to the NAPA counter and ask the partsman for a 1/8" breakaway ferrule and some 1/8" copper tubing. Thought I would share a pic with you. This is my oil pressure line on top with the vacuum gauge line on the bottom. I used 4-AN line and bulkhead fittings.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-02-2004, 11:56 PM   #18
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
Hey dubie when ya pull that line off for your oil pressure I'm interested in the fitting that goes into the block that the round cylinder screws in.You wanna sell that?
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 01-03-2004, 12:45 AM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Gonebad, I'd like to see more pictures of your truck please.
Not just the braided hoses, the whole engine and everything.
Thread Tools
Display Modes
